Go Back  R/C Tech Forums > General Forums > Oval, Larger Scales and More
Just Showing Off Pictures of My 5B >
Old 12-24-2009, 02:45 AM
RacerX20's Avatar
Default Just Showing Off Pictures of My 5B
Here is my Baja 5B and all of its parts and hop ups. I don't even want to know how much I've spent.
Engine:
CY / RC 35mm 26.9cc Big-Bore Kit
DDM Dominator Chrome Pipe
Walbro WT-813 High-Performance Carburetor
Snappy RC Ultimate Fuel Line Kit
TGN 'Redneck' Dual Stage Pre-Filter
ADA RC Manifold
Dual Screen "Crap Trap" In-line Fuel Filter
Large Body Billet In-line Fuel Filter
Drivetrain:
Lauterbacher Adjustable OFFROAD 4-Shoe Billet 54mm Clutch
TR Clutch System SILVER
17T,18T,19T pinion for TR clutches
Hostile Plastic Spur Gear
Team FastEddy Diff Oil 30K
SS Driveshafts
Darksoul V2 Axle Extender
Darksoul Enclosed Blue Nut Set
Tires:
Sand Buster M Compound Front Rib Tire Set
Sand Buster M Compound Rear Paddle Tire Set
Silverback Beadlock Rings OUTER Blue
Silverback Beadlock Rings INNER Blue
Front Super Star Wheel Gunmetal Set
Rear Super Star Wheel Gunmetal Set
DDM Stainless Steel Beadlock Bolts
Durability & Protection:
Team FastEddy "Race Series" Hardened Front Turnbuckles
ModifiedRC Quick Release Aluminum Roll Cage Tubes
Yamadude Throttle Linkage
Outerwears Prefilter
Outerwears Pull Start Cover
Heavy Duty Aluminum Brake Mount
Aluminum Steering Arm
Electronics:
Pro-Match 6v 4200mAh Hump Receiver Battery Pack
Futaba R604FS 2.4GHz Receiver
Modified Pico Kill Switch with LED Mod
Hobbico VoltWatch Battery Monitor
Dual CREE Emitter Headlights Mod
Dimension Engineering 3A Voltage regulator (for headlights)
Suspension:
Turtle Racing Shock Mount - Silver
Turtle Racing Tower/Mount - Silver
Threshold "Crowns" Pre-Load Adjustment Collars
UberRC Baja Shock Socks
Killer RC "Killer Cables" Suspension Limiting Cables
Shockwears
GH Rear Aluminum Shock Support Silver
Aesthetics:
M&R Anodizing Finish
TGN Pull Start Handle
DDM Billet Gas Cap
Rhino Choke Lever
Rhino Wing Pins
Billet Fuel Line Clamp
Blue fuel line
TGN Fuse Wing Wrap
FF Clear Front/Side Windows
Complete Clear Body
Other:
Modified RC Billet Front Light Mount
RC Piston Stopper
Body Clip Set 8mm
Fuel Line Clips
Pics:
-Tony
RacerX20 is offline
Old 12-24-2009, 05:39 AM
Chris K's Avatar
Trader Rating: 46 (100%+)
Sweet RIDE(s) and NICE cat!!!!!!
They're so funny how they'l 'pose' for about 2 seconds and then off to the next shiney object!!!!!!!!!!!
Chris K is offline
Old 12-24-2009, 09:10 AM
hndaman1's Avatar
Talking
nice, so now get it dirty
hndaman1 is offline
Old 12-24-2009, 06:00 PM
RacerX20's Avatar
It is now~
-Tony
RacerX20 is offline
Old 12-24-2009, 06:37 PM
Trader Rating: 33 (100%+)
Looks liken you had a major tire malfunction. What caused that? I've never seen one torn like that.
Good looking baja. I have 2 5T's myself. They are a blast.
hairdog is offline
Old 12-24-2009, 07:02 PM
Trader Rating: 264 (100%+)
That thing is nice!!!
92 vert is offline
Old 12-24-2009, 07:30 PM
RacerX20's Avatar
Thanks!
I think it was just debris in the sand. So I had to run the dirt busters in the sand for a bit. That sucked.
-Tony
RacerX20 is offline
Old 12-24-2009, 07:36 PM
NochikenStrips's Avatar
very nice indeed! Loving the exhaust!
NochikenStrips is offline
Old 12-24-2009, 08:41 PM
I'm sure it sucked big time. I drove my 5t on the beach with excavators on it and it was a turd.
hairdog is offline
Old 12-25-2009, 05:09 AM
hndaman1's Avatar
Questions??
where is the foam in the rear tire? or did it get torn out?
hndaman1 is offline
Old 12-25-2009, 02:17 PM
RacerX20's Avatar
I don't run foams in the rear. You don't need em. The tire will balloon and expand. Running foams adds a bit of weight and adds rotational inertia to the drivetrain. Those tires probably just failed because they were a little old. I got good use of of them. I've replaced them and did a full rebuild.
-Tony
RacerX20 is offline
Old 12-28-2009, 07:49 AM
hndaman1's Avatar
Wink
do you know what version rear wheels you are running? if you dremel away the sharp inner lip of rim near the bead, it stops the tires from rubbing/ripping from the inside..
on some of the rims that lip is really sharp and rubs the inside of the tires and wears them away, and causes them to rip, and since you not running any foams it might rub faster..JMO
hndaman1 is offline
Old 12-31-2009, 03:23 AM
Dude, that's a killer Baja. I have a new 5B on the way here. Here's my 5T:
Vert1go is offline
Old 12-31-2009, 04:11 AM
RacerX20's Avatar
Enjoy it while it's new and clean. After the first run it will never be that clean again.
-Tony
RacerX20 is offline
