NEW Corally Asuga XLR Buggy Xtra Large bigger than 1/8
This will be awsome i believe. 20-25% bigger than 1/8 Radix
Finally a bigger Buggy than 1/8
looks like a 1/7 scale
https://youtu.be/bqB86Inht8U
More info in less than 24h
Here is info
it is 15% bigger than 1/8 buggy,
This comes ROLLER and also RTR With 6s combo and radio
599$ for RTR and 379$ for the Roller
Fifteen percent bigger than the average 1/8 buggy, with higher ground clearance, more suspension travel, and oversized components-in short, a completely new chassis that still uses the proven drive components of Corally's existing 6S models. Note the many details, and it will soon become clear to you that the ASUGA XLR has set a new standard for RTR RC cars.
The precision CNC-manufactured aluminum parts, the beautiful red anodization, and the various small details make a big difference.
-70% parts compatibility with existing Team Corally 1/8 scale models
-Massive, 3mm thick aluminum main chassis plate with protective side guards
-Ultra rigid hybrid central chassis brace system
-CNC-machined adjustable aluminum motor mount with aluminum and steel center diff assembly
-Massive 16mm big bore, threaded aluminum, oil-filled shocks with hard springs, heavy-duty 4mm tuned pistons, and oversized lower shock ends.
-5mm thick, CNC-machined aluminum front and rear shock towers
-Massive heavy-duty composite suspension arms, with aluminum hinge pin and pivot ball retainers for impressive durability. The front upper arms feature a unique aero control kit for additional downforce and improved steering response.
-Extreme 8mm-thick aluminum suspension pin holders secured by eight 4mm mounting screws include adjustable composite toe-in blocks.
-Large, heavy duty composite steering blocks with new pillow ball securement features
-Oversized composite rear hubs
-Durable composite steering and upper-camber links
-Three fluid-filled precision differentials with CNC spiral-cut metal input and main gears
-Durable, hardened S2 steel drive joints and axles
-Rubber sealed ABEC-3 ball bearings
-Chassis skid plates with integrated modern front bumper
-Low-profile 130mm Sprint RXA high-grip tires designed for 6S power
-Reliable CT2R pistol grip 2.4 GHz transmitter and receiver with digital trims, steering dual rate, and servo reversing
-Powerful Kuron 825 4-pole, 2050kv sensorless brushless motor
-Smooth and reliable 6S-capable Torox 185 ESC with LVC and user-adjustable BEC and profile settings
- HV7225 digital high-speed steering servo with metal gears and a whopping 25Kg of torque.
Larger than in size than other models with additional ground clearance, massive suspension travel, and oversized components, the Asuga XLR is a completely new chassis that employ the proven drive components of existing Team Corally 6S-powered models. The impressive size of the Asuga XLR delivers razor-sharp handling, amazing acceleration, top-speed, and unsurpassed durability. Reset your expectations and go big with Team Corally's Asuga XLR RTR.
One thing is sad
Chassis is only 3mm. This Big Buggy should have atleast 4mm , or 4.5mm
One thing is sad
I will buy one of these, Roller version
Arms and stuff looks beefy.
Only thing that worries is the 3mm chassis.
Anyways, i will not do huge jumps with this. I will be fine, and if not there will be 7075 swiss made chassis as option 3mm that will handle atleast medium jumps well .
Also 7075 swiss made chassis braces will come to this in Options from Corally i saw
If you jump insane, you need wait and see if M2C will do 4-5mm 7075 chassis.
If you like to drive fast, and run a stabile buggy without huge jumps you will be fine with stock chassis or atleast with the Corallys own coming 7075 swiss 3mm option chassis.
I wish there will be competition,
that Arrma also release 1/7 Buggy, roller with 4-5mm chassis , and one RTR maybe.
Personally i prefer rollers.
Love to choose my electronics self
Wheels looks almost same in size like 1/8 Truggys got. Or maybe they are same.?
Im pretty shure most aftermarked 1/8 Truggy wheels will fit this car.
- -Low-profile 130mm Sprint RXA high-grip tires designed for 6S power
- -Reliable CT2R pistol grip 2.4 GHz transmitter and receiver with digital trims, steering dual rate, and servo reversing
- -Powerful Kuron 825 4-pole, 2050kv sensorless brushless motor
- -Smooth and reliable 6S-capable Torox 185 ESC with LVC and user-adjustable BEC and profile settings
Size:
Length: 574 mm
Width: 359 mm
Height: 192 mm
Wheel base: 371 mm
Weight: 4450 g
Max. possible Speed: 110+ km/h
It is about 2inch wider and also almost 2inch longer wheelbase than 1/8 Buggies.
Now we have all info.
Only thing left is wait for Videos on youtube be released from guys like
RCDriver_Online and others who unbox this and Bash it decent.
I believe there will be at least couple today
If videos dont show any huge problems with this car i will buy one Green Roller.
How about you?
Electronics i will use in my Roller will be :_
Servo 35-45kg digital
Stock motor is 41x74mm 2050kv in RTR , so im thinkin New Max8 Combo 4278 2250kv Sensored 160amp ESC
HW38010400S
Here you can see how much parts cost, like wheels, new body, new diffs, and other stuff
https://www.corally.com/Car-Models/R...S-Roller-Blue/
This new MAX8 combo runs about 25% Cooler than the old MAX8. Also it has Alot more functions and settings Like Turbo that adds about 25% more power.
Battery tray dimensions: (LxWxH): 160x50.5x63 mm
Big lipos will fit
€ 61,95
C-00180-687TEAM CORALLY - DIFF ASSEMBLY - FRONT / REAR - 43T BEVEL GEAR - XPERT BUILD - 20K OIL FILLED - 1 SET
- € 47,95
C-00180-857TEAM CORALLY - POLYCARBONATE BODY - ASUGA ASUGA XLR - CLEAR - CUT - 1 PC
€ 10,95
C-00180-860TEAM CORALLY - SUSPENSION ARM HDA-3 - LOWER - REAR- COMPOSITE - 1 PC
- € 79,95
C-00180-685-1TEAM CORALLY - CENTER DIFF ASSEMBLY - ALUMINIUM / STEEL - 52T MAIN GEAR - XPERT BUILD - 100K OIL FILLED - 1 SET
C-00180-891TEAM CORALLY - HINGE PIN - FRONT UPPER ARM - STEEL - 2 PCS
- € 19,95
C-00180-895TEAM CORALLY - DOGBONES - HDA-3 ARMS - REAR - STEEL - 2 PCS
- € 34,95
C-00180-878TEAM CORALLY - SHOCK TOWER - ASUGA XLR - 5MM - ALUMINUM - REAR - 1 PC
€ 134,95
- C-00180-1124
TEAM CORALLY - CHASSIS - ASUGA XLR - SWISS MADE 7075 T6 - 3MM - HARD ANODISED - BLACK - MADE IN ITALY
€ 43,95 € 48,95
- C-00180-865
TEAM CORALLY - CHASSIS BRACE - ASUGA XLR - REAR - SWISS MADE 7075 T6 - 3MM - HARD ANODISED - BLACK - MADE IN ITALY - ...
C-00180-1123TEAM CORALLY - SHOCK TOWER - ASUGA XLR - REAR - SWISS MADE 7075 T6 - 5MM - HARD ANODISED - BLACK - MADE IN ITALY
there is alot options to this car
First real run video of this Car
from Corally them self
bashing
https://youtu.be/ZuYgyJoPZcE
presentation video new Asuga XLR
https://youtu.be/V3xtMWwYa9U
Now i wait for the RC Reviewers videos,Youtubers who unboxing and bashing this
bashing
I have change my Mind
past release Corally XTR 2022
is actually better rig.
Alot 7075 parts
Roller
Almost same price.
Alot 7075 parts stock
Longer Wheelbase also
More stable, stronger.
Why buy this buggy xl ?
Just buy truggy wheels to that Corally XTR 2022 AND you have better more stable car.
Stronger parts also from box.
More protection also from that body
This release is not better than Corally XTR 2022 if you want roller.
The XTR Roller Muggy / truggy/monster is actually better.
At this moment the best choise to buy is
Hard Bashing
Arrma Kraton EXB roller 1/8
Track and fast driving without huge terrain and jumps
Corally XTR 2022 roller
Kraton handles more abuse
Corally XTR is more tight and nice drive fast with.
Not for big jumps or crash hard.
Last you want is this new Big Buggy without 7075 parts.
Go buy the 2022 Corally XTR or Arrma EXB Kraton , or Talion EXB RTR Will be better than this new Corally standart Huge buggy
Alot 7075 parts
Roller
Almost same price.
Hard Bashing
Great video out now from Tomley. He test drives it at BMW Track.
https://youtu.be/pE54396uiC0
Normal bashing, less than 30mph and bent shocktower.
It looks really good other than that.
Size and weight makes it grip very good at loose track with stock tyres.
If you use Proline, AKA, or Sweep Truggy tyres you will have even more grip
Nice balance, it does jumps great. This likes to fly far
Corally are nice in handling. Precision.
Great Video
Big heavy buggy like this , needs 7075 front shock tower.
I believe the chassis and rear tower covered by rear wing will last for normal bashing like Tomley did in this video.
It needs the option front shock tower, because it is a big Buggy.
Kronos XTR is great because it has body that protects front shocktower, and it has also 7075 parts.
I like that Corally made 1/7 buggy, or 1/8 xl buggy ?
Wonder when they will stock the 7075 hop ups ?
Most will need this Option Part for shure:
€ 42,95
Link to Options:
https://www.corally.com/New-Products...S-Roller-Blue/
go to OPTIONALS below pictures in that link
Here is alot options to this rig:
<iframe width="560" height="315" src="https://www.youtube.com/embed/pE54396uiC0" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" allowfullscreen></iframe>
Great Video
€ 42,95
Link to Options:
C-00180-1126TEAM CORALLY - CHASSIS BRACE - CENTER UPPER - ASUGA XLR - SWISS MADE 7075 T6 - 3MM - HARD ANODISED - BLACK - MADE IN ...
OUT OF STOCK
DETAILS
C-00180-203TEAM CORALLY - ANTI-ROLL BAR - 3.0MM - REAR - 1 PC
IN STOCK
BUY NOWDETAILS
C-00180-704TEAM CORALLY - STEERING RACK - SWISS MADE 7075 T6 - 3MM - HARD ANODISED - BLACK - MADE IN ITALY - 1 PC
IN STOCK
BUY NOWDETAILS
C-00180-866TEAM CORALLY - CHASSIS BRACE - ASUGA XLR - FRONT - SWISS MADE 7075 T6 - 3MM - HARD ANODISED - BLACK - MADE IN ITALY -...
OUT OF STOCK
DETAILS
C-00180-196TEAM CORALLY - ANTI-ROLL BAR - 2.5MM - FRONT - 1 PC
IN STOCK
BUY NOWDETAILS
C-00180-288TEAM CORALLY - SHOCK SPRING - HARD - TRUGGY / MT - REAR - 1.8MM - 95-97MM - 2 PCS
IN STOCK
BUY NOWDETAILS
C-00180-909TEAM CORALLY - SPRINT RXA - ASUGA XLR STREET TIRES - LOW PROFILE - GLUED ON BLACK RIMS - 1 PAIR
OUT OF STOCK
DETAILS
C-00180-1124TEAM CORALLY - CHASSIS - ASUGA XLR - SWISS MADE 7075 T6 - 3MM - HARD ANODISED - BLACK - MADE IN ITALY
OUT OF STOCK
DETAILS
C-00180-201TEAM CORALLY - ANTI-ROLL BAR - 2.6MM - REAR - 1 PC
IN STOCK
BUY NOWDETAILS
-3%
List price
€ 38,95
C-00180-410TEAM CORALLY - XTREME DIFF CASE - 30MM - ALUMINIUM 7075 - HARD ANODISED - BLACK - FRONT / REAR - MADE IN ITALY - 1 PC
IN STOCK
BUY NOWDETAILS
-8%
List price
€ 69,95
C-00180-854TEAM CORALLY - GEARBOX CASE SET - SWISS MADE 7075 T6 - BLACK - SET
IN STOCK
BUY NOWDETAILS
C-00180-157TEAM CORALLY - WING WASHER - LIGHTENED - ALUMINUM - 2 PCS
IN STOCK
BUY NOWDETAILS
C-00180-224TEAM CORALLY - FAN HOLDER FOR FAN 40 MM - COMPOSITE - 1 SET
IN STOCK
BUY NOWDETAILS
C-00180-892TURNBUCKLE - M5 - 70MM - S2 SPRINGSTEEL - 2 PCS
IN STOCK
BUY NOWDETAILS
C-00180-1122TEAM CORALLY - SHOCK TOWER - ASUGA XLR - FRONT - SWISS MADE 7075 T6 - 5MM - HARD ANODISED - BLACK - MADE IN ITALY
OUT OF STOCK
DETAILS
C-00180-198TEAM CORALLY - ANTI-ROLL BAR - 2.2MM - FRONT - 1 PC
IN STOCK
BUY NOWDETAILS
C-00180-291TEAM CORALLY - SHOCK SPRING - HARD - BUGGY REAR - TRUGGY / MT FRONT - 1.8MM - 84-86MM - 2 PCS
IN STOCK
BUY NOWDETAILS
C-3106-30-5TEAM CORALLY - ALUMINIUM NYLSTOP NUT - M3 - RED - 10 PCS
OUT OF STOCK
DETAILS
C-00180-1125TEAM CORALLY - CHASSIS BRACE - CENTER LOWER - ASUGA XLR - SWISS MADE 7075 T6 - 3MM - HARD ANODISED - BLACK - MADE IN ...
OUT OF STOCK
DETAILS
C-00180-202TEAM CORALLY - ANTI-ROLL BAR - 2.8MM - REAR - 1 PC
IN STOCK
BUY NOWDETAILS
-3%
List price
€ 40,95
C-00180-411TEAM CORALLY - XTREME DIFF CASE - 35MM - ALUMINIUM 7075 - HARD ANODISED - BLACK - CENTER - MADE IN ITALY - 1 PC
IN STOCK
BUY NOWDETAILS
C-00180-865TEAM CORALLY - CHASSIS BRACE - ASUGA XLR - REAR - SWISS MADE 7075 T6 - 3MM - HARD ANODISED - BLACK - MADE IN ITALY - ...
OUT OF STOCK
DETAILS
C-00180-195TEAM CORALLY - ANTI-ROLL BAR - 2.6MM - FRONT - 1 PC
IN STOCK
BUY NOWDETAILS
-24%
List price
€ 24,95
C-00180-266TEAM CORALLY - SERVO SAVER STEERING ARM - 7075 T6 - HARD ANODISED - BLACK - 1 PC
IN STOCK
BUY NOWDETAILS
C-00180-903TEAM CORALLY - HD STEERING BALL JOINT - COMPOSITE - 1 SET
IN STOCK
BUY NOWDETAILS
OUT OF STOCK
DETAILS
C-00180-199TEAM CORALLY - ANTI-ROLL BAR - 2.0MM - FRONT - 1 PC
IN STOCK
BUY NOWDETAILS
C-00180-316TEAM CORALLY - SHOCK CAP - LOWER - ALUMINUM - 2 PCS
IN STOCK
BUY NOWDETAILS
videos
I still Wonder why RC Driver and other Big Youtubers have not test this car.
Tomley from UK is the only big Youtuber who run it, he did bend the Front Shock Tower at normal bashing *nothing crazy*
Is there anyone who sell 7075 shocktowers to this car ?
TC Asuga XLR Speed Run! +MethodRC Tires
https://youtu.be/Mdtw_0_p4tUTEAM CORALLY ASUGA XLR torture test in the cold ❄️
https://youtu.be/Ux_h4pNQbd0Super Speed Saturday - Team Corally ASUGA XLR 6s Test w/18t pinion and big street wheels
https://youtu.be/EpZPWaYw4TUI still Wonder why RC Driver and other Big Youtubers have not test this car.
