Go Back  R/C Tech Forums > General Forums > Oval, Larger Scales and More
Street Stock Buggy based oval questions >
Old 02-21-2021, 03:36 PM
Herc Driver's Avatar
Default Street Stock Buggy based oval questions
Hey guys,
I recently converted my 6.1d to street stock and want to pick the brain of someone who’s figured this out.
Known- buggy comes with 3 degrees of rear toe/not ideal for oval
Question- utilizing the C/D block “pills” how to I keep LR toe and lessen RR toe or even toe it out to help on oval?
The obvious answer (seems to be) is to move the front blocks (I think this is the C block) right side “pill” laterally to the right and leave the front left one alone. (Up and down is anti squat...that’s the next question...HA)
if this is correct, what about the other block? The D (further back block)?
I've looked at the Pill setting sheet but I guess I need a more broad/“for dummies” explanation.
thank you to all the Oval Sun Gods in advance!
Herc Driver is offline
