Like Tree1Likes
Uh Oh...
Old 01-07-2021, 01:06 AM
  #16
Daksh's Avatar
Originally Posted by Lone Racer View Post
Razor blade. Just try not to get any inside the crankcase.
Thank you for the help!
Daksh is offline
Old 01-07-2021, 08:17 AM
  #17
Mad Max's Avatar
Why are you cleaning the piston? The carbon buildup builds compression and will create more power. I only am changing heads and pistons when compression is slipping. I run limited class oval with a restrictor and stock exhaust.
Mad Max is offline
Old 01-07-2021, 08:59 AM
  #18
Daksh's Avatar
I thought it was better to have a cleaner piston, I am also going to a thinner head gasket so I thought it might be a good idea to clean it off
Daksh is offline
Old 01-07-2021, 10:14 AM
  #19
Sir 51D3WAYS's Avatar
1.Just make sure the black stuff on the piston isn't an actual hole/divot, that would indicate that the piston is about to let go pretty soon.
2. 500 grit is a little too coarse for most RC purposes, unless if the buildup is really heavy. I would switch to 1000 as soon as I got the worst of it off. Next time try at least a 1000, doesn't matter if you clog up a few sheets, sandpaper is dirt cheap anyway, plus the scratches that you leave will be super fine and almost invisible to the naked eye.
3. You should use a plastic scraper to scrape off the remnants of the gasket, using sealant/gasket removal chemical if necessary. This chemical is usually nasty stuff, so wear PPE as appropriate. A metal blade/scraper will scratch the head, creating grooves that would allow fluids to leak past the gasket.
4. Carbon buildup on a piston is generally bad news, even if it raises compression ratio. The carbon will (usually) build up unevenly, causing random hotspots around the piston/combustion chamber, which in turn causes pre-ignition and subsequent detonation, which will put a hole in your piston.... This is not the same as your usual blackening/browning of your piston associated with normal use....
Sir 51D3WAYS is offline
Old 01-07-2021, 10:27 AM
  #20
Daksh's Avatar
hello, I will use 1000 grit next time, thank you for the advice, I can use chemicals to get the gasket off right? I have some stuff at home called goof off, you use it to take off the residue of labels when you remove them.
Daksh is offline
Old 01-07-2021, 10:53 AM
  #21
^yup. Just make sure it's clean and dry before applying the new gasket.
Old 01-07-2021, 11:54 AM
  #22
Daksh's Avatar
Thanks for the help!
Daksh is offline
Old 01-07-2021, 02:13 PM
  #23
the rc guy's Avatar
the rc guy is online now
Old 01-07-2021, 03:16 PM
  #24
Why should he replace the piston? What wears is the cylinder walls not the piston and the new ring will give him more compression so that will be barely noticed. Keep doing what your doing bud. It's not rocket science.
Lone Racer is offline
Old 01-07-2021, 03:23 PM
  #25
Daksh's Avatar
my new piston ring is coming today, just for curiosity, how do you inspect if the cylinder has worn too much?
Daksh is offline
Old 01-07-2021, 03:34 PM
  #26
the rc guy's Avatar
Old 01-07-2021, 03:46 PM
  #27
Experience will tell you. After a few re rings you'll notice it's easier to yank on the pull start. That's when the cylinder is worn and lost most of it's performance. They still run just less compression which equals less power.
And I don't see any holes, just 2 carbon spots.
Old 01-07-2021, 04:09 PM
  #28
Daksh's Avatar
I see, thank you, and yes those are just carbon spots, i buffed them out with metal polish and a micro fiber towel
Daksh is offline
Old 01-11-2021, 10:40 PM
  #29
How'd everything work out, you get your rig running?
Old 01-11-2021, 11:19 PM
  #30
Daksh's Avatar
yup, doing break in right now, everything working perfectly, thank you for the help!
Lone Racer likes this.
Daksh is offline
