Go Back  R/C Tech Forums > General Forums > Oval, Larger Scales and More
Which Losi 5b electric conversion >
Like Tree8Likes
  • 1 Post By gavsta72
  • 1 Post By mustangman50
  • 1 Post By werner sline
Old 08-26-2020, 03:22 PM
Default Which Losi 5b electric conversion
There is a few out there. Iím looking to run a leopard v2 700kv with a Ztw beast pro on 12s.
the tlr kit I canít find anywhere because itís discontinued so Iím seeing what you guys like or have used.
I like the tlr kit because of the staggered battery trays
Any help will be great
thanks
albert
mustangman50 is offline
Old 08-26-2020, 09:23 PM
gavsta72's Avatar
That's a shame, I just had a look around and it seems it's finally completely discontinued.
I used it in my last 2 5iveB builds, much better than the RCmadness one I used in my first build, although the TLR wasn't around then
I'm running the Max5 and Leopard 58113 870kv on 8S of course, which is plenty enough for the 5iveB as it's lighter enough, and she's pretty quick. 12S on the 5iveT for sure though
Using the 15T pinion that comes with the kit, but I could easily gear it up to 16T, and 17T with a cooling fan, but I don't do cooling fans, that means you're running an inefficient high amp drawing system
I'm using the MCD RR5 cab forward body as it has no holes, and is low profile. Also using an MCD wing as they look the goods compared to the stock wing, and the Extreme Racing centre diff top plate to complete the carbon fibre parts
werner sline likes this.
gavsta72 is offline
Old 08-26-2020, 09:42 PM
Looks great how do you like one servo up there? I was going to use two up front. Where did you get the arms on that from the servo to the bellcrank?
i was planning on going crazy and using two spektrum 9120ís up front. But I can use one for the brake and one for the steering the torque is impressive on these servos
gavsta72 likes this.
Old 08-26-2020, 09:48 PM
Just found one on eBay and picked it up
Old 08-26-2020, 09:52 PM
gavsta72's Avatar
They're the IRP 5iveT v1 links from DDM. I prefer a single servo with a push 'n pull setup, no need for 2 servo's imo, it's just more amp draw from the ESC, and a 70kg servo like the Hilantronics I use is more than enough. Plus 2x servos costs twice as much lol
gavsta72 is offline
Old 08-26-2020, 09:53 PM
gavsta72's Avatar
Aaah nice one, I was going to say there would be some floating around somewhere
gavsta72 is offline
Old 08-28-2020, 05:17 AM
werner sline's Avatar
damn i love that body !
what lipos do you use ?
werner sline is offline
Old 08-28-2020, 02:41 PM
gavsta72's Avatar
Haha cheers, they are nice bodies, and nicely low slung as you can see. They look much better in person though
After seeing people raving about the Zeee Power lipos I thought I would try them. I'm using the 4S 6500mah 80c with xt150 connectors. They supply the power no problems and barely get warm. Very impressed. Nice and cheap on ebay
gavsta72 is offline
Old 09-01-2020, 09:13 PM
Sheís coming together waiting on my electric conversion
Old 09-03-2020, 08:08 PM
a little more done
Old 09-07-2020, 02:23 PM
gavsta72's Avatar
Looking good mate. She's a very nice kit
Just one thing, and I see allot of people doing the same thing. The o-ring goes inside the top of the shock cap, then screw it on
gavsta72 is offline
Old 09-08-2020, 05:10 AM
Iíll swap that. It has an ORing In the groove of the cap also. Thank you
Old 09-14-2020, 12:02 AM
gavsta72's Avatar
I did it myself with my first build, it wasn't until I bought a 5iveT 2.0 and the o-ring was in the cap that I realized. The build manual isn't very clear on that
gavsta72 is offline
Old 09-14-2020, 04:47 PM
Sheís getting there
Old 09-21-2020, 01:58 PM
