Go Back  R/C Tech Forums > General Forums > Oval, Larger Scales and More
Cooling a 56/58mm can motor >
Like Tree4Likes
  • 1 Post By gavsta72
  • 1 Post By .AJ.
Old 06-11-2020, 07:28 AM
Default Cooling a 56/58mm can motor
Anyone know of any heat sinks for a large size motor? Castle has a plastic .... fan and mount thing but plastic isnít the best at releasing heat
illmatic94 is offline
Old 06-11-2020, 08:11 PM
gavsta72's Avatar
The Castle fan/shroud does a great job blowing cool air around the motor can. Plastic or not, it's the fans doing the job and you can expect temps to drop by a good 20+
rudebwoyfishman likes this.
gavsta72 is offline
Old 06-12-2020, 11:06 PM
ive done it with and without. Maybe Iíll get higher rpm fans
Old 06-12-2020, 11:22 PM
gavsta72's Avatar
Yeah allot of people use the Yeah Racing Tornado fan
I actually use the SkyRC fan/shroud as it's readily available here, and the fans are actually screwed in for easy removal. I use the YR fans
gavsta72 is offline
Old 06-13-2020, 01:53 AM
.AJ.'s Avatar
Or just gear your motor properly and do away with the need for a fan altogether
.AJ. is offline
Old 06-13-2020, 07:11 PM
gavsta72's Avatar
Well that's true to of course, however i don't use a fan because a motor is getting too hot, i use a fan to keep it even cooler, 20deg below the maximum recommended
gavsta72 is offline
Old 06-14-2020, 05:01 PM
Thereís no fun in that.
Old 06-15-2020, 08:28 AM
.AJ.'s Avatar
Run 12s and it’s plenty fun lol
.AJ. is offline
Old 06-17-2020, 05:03 PM
Run 12s and itís plenty fun lol
What Esc could I use . Iím running the xlx
Old 06-28-2020, 11:10 PM
I know that there are water cooling jackets out there for boats. I have one but you would have to do alot of extra work to make it work.
RubberMatt is online now
Old 06-30-2020, 04:59 PM
Motiv fans are the only way to go
Krazykurt88 is offline
