Street Stock
Old 06-01-2020, 07:58 AM
Braxamus's Avatar
Default Street Stock
I am running a B6.1D lite that has been converted to run on a dirt oval as a street stock. The track is a smooth med to low bite surface that gets dusty/gritty with sand, whats the best thing to run a slipper or a slipper eliminator? Also whats the best trans to run laydown, layback ? we run the custom works adjustable rear arms for rear steer I can get the car to turn in pretty good but rear end is loose coming out unless I baby it so much it slows down way to much.
Braxamus is offline
Old 06-27-2020, 02:21 PM
Trader Rating: 94 (100%+)
Hopefully solved by now, but loose off with adj. rears would like a decrease in LR toe in, or first I might try adding cross weight by a round or two in RF and LR … (RR corner for entry, LR corner for exit)
tomkatn is offline
