Losi DBXLE 2.0
#151
Ok I will try to recalibrate my radio, will see . I hope that will take care of the problem.
#152
Yes these tires are sick. The car drives so stable and the damping is little firmer also.
My rear right diff bearing is making a screeching noise since it was new. I think it needs to be changed but I will wait until the next diff oil change and hopefully FID comes out with the 2.0 parts because I really really want those orange diff cups.
Also got a sawna transmitter and ditched the crappy spektrum.
#153
I recalibrate the radio several times and still some problem, car will go to the reverse on second brake application.
#154
Anyone have a problem with the car making high pitch winding sound at full throttle?
Problem solved.y center diff had lots of back and forth movement. Need to shim it properly.
#155
Well I thought I bought a 16 tooth pinion but Instead I bought a 13 tooth stock pinion and put it on and I noticed no change at all. Later on I found out I bought a 13 tooth. Lol. Waste of $20
#156
Posts not showing up...
Seems like the large scale crew is still doing well. Idk what’s happening but some of my posts aren’t showing up (something to do with a moderator needing to approve them)!? Hopefully this one shows up and the moderators can assist with the issue.
On the V2, just waiting on some Losi chassis strengthening parts and a 17t pinion. Took it on a maiden drive in my backyard desert (Arizona) and it runs really well!! Also, you guys have any experience with high torque/speed 1/5th scale servos? Looking to beef up the steering without going to a dual setup.
#157
Spektrum s9020 for around $200. I did go the dual servo setup because it was cheaper and you get the same amount of torque as the s9020. Came out to $90 servo,arms and Y splitter.
#158
Niz...I can get the 9020 Spektrums for a good bit cheaper than MSRP so I will likely go with that for a single setup (that’s the one I had my eye on anyway)
#159
The 7010D 70kg will set you back $169
https://www.detroitperformancerc.com/copy-of-inertia
#161
Can't beat the mighty Hilantronics Hercules range, 40,50,or 70kg. Much better than the Spektrum. These are now the go to servos for large scale. I've been running them for a good 12 months and they are by far the best I've used, super quiet, fast, and very smooth
#162
Is all about warranty. And for. $200 servo I will definitely go with spektrum and horizon great warranty.
#164
What about the Hitec D845WP? the s9020 is better than it?
