IDM T3 PISTON/LINER REPLACEMENT
Will the ns12s3 or nsr12s3 piston/ liner set work in the
above engine? Cheers |
if the crankcase is the old type yes..........
if the cranckcase is the new type (with one more cooling fin on the top) you must replace with the LS3/ Rex LR3/ Top LT3 rebuild kit........ |
| All times are GMT -7. It is currently 03:31 AM. |
