-   Onroad Nitro Engine Zone (https://www.rctech.net/forum/onroad-nitro-engine-zone-71/)
-   -   OS v-spec (https://www.rctech.net/forum/onroad-nitro-engine-zone/99425-os-v-spec.html)
Matthew.H 01-26-2006 05:36 PM
OS v-spec
Hey i need to no which two pipes work best on a small track and a big track
Tag 01-27-2006 09:18 PM
I used to run OS V-spec, jammin's JP-1 works great on smaller track as it gives you some mad torque , for tracks that have longer straightway then go with JP-2 it provides better top end without sacraficing too much low end torque. anyways, v-spec is a torquey engine to start with you will be happy with either, good luck
Matthew.H 01-27-2006 10:09 PM
thanks for the info
Old Skool 02-07-2006 10:46 PM
OS 2050 pipe and header hands down. Tried my V-Spec with both the JP-2 (low-mid range pipe) and JP-2 (mid to top-end). Retuned for both pipes and the V-Spec produced the most usable power with the 2050.
noobie 02-08-2006 03:56 AM
i've gotta throw the RB053 with long header in there! works awesome.
SpeedBump57 02-08-2006 09:37 PM
Mattman OS-2050. ;)
Matthew.H 02-08-2006 09:40 PM
ok thanks
