-   Onroad Nitro Engine Zone (https://www.rctech.net/forum/onroad-nitro-engine-zone-71/)
-   -   What Tuned Pipe to run ? (https://www.rctech.net/forum/onroad-nitro-engine-zone/980926-what-tuned-pipe-run.html)
BigC2007 03-08-2017 12:54 PM
What turned pipe to run with a Novarossi VIR-TUS Tuned 9-Port .21 XLong Stroke ?
Glutton 03-14-2017 06:31 AM
Never owned this engine personally but friend of mine was running his with the 2015 and the 2122 pipe with good results. Seems like you can't really go wrong with the 2015 pipe seeing as its the most popular choice for many people. I believe the 2122 pipe is very similar to the 2015 too.
BigC2007 03-14-2017 06:34 AM
Originally Posted by Glutton (Post 14869175)
Never owned this engine personally but friend of mine was running his with the 2015 and the 2122 pipe with good results. From what I understand you can't go wrong with the 2015 pipe (seems like the most popular choice for top racers) and I believe the 2122 pipe is very similar.
Thanks Glutton
1/8 IC Fan 03-14-2017 06:41 AM
Also check out here: VIR-TUS.21 Onroad - NOVAROSSI WORLD
Their old page has a few recomendations too
BigC2007 03-14-2017 06:51 AM
Thanks Fan for the link good info.
desotoracing 03-14-2017 10:38 AM
51010 pipe (2015) with the 41015 header
BigC2007 03-14-2017 11:33 AM
Thanks for the info on the 41015.
Roelof 03-14-2017 11:51 AM
It is also wise to try the 41016 header as well. it does give more bottom power w/o much loss on top rpm. Depending the track it could be the better choice.
BigC2007 03-14-2017 11:59 AM
Nice thanks Roelof, its always good to have some bottom end power and without to much loss on the top end that sounds like a win win.
