Nova P5XLT for GT
Would a Novarossi P5XLT be suitable for GT? If so would the Nova 41014 header and the Nova 2015 pipe be ok?
So I take it that no one knows.
Originally Posted by petersen114
(Post 14838967)
AFM |
Originally Posted by afm
(Post 14853194)
You can use it, but if your track is a fast track it will probably heat up, because it is designed for torque, not high speed...any way if you have it and want to use it , better use it with Nova 41032 header and the 2015 pipe, and if you can place a 0.10mm shim under the sleeve and remove same amout on the head, it will perform much better overall.
AFM |
I am using a Nova ison tuned on-road engine now in the car. Was wanting something 5 port though to make it all legal. Guess I will try to sell the ison and get a dedicated GT engine.
(Post 14858202)
get a tuned pipe with top speed performance, i think should be good enough. but it cant compares with onroad engine, they had a high peak rpm than offroad engine.
I would like to stick w/ Novarossi. I know about the ison GT. Is there another gt engine they offer???
(Post 14864437)
AFM |
(Post 14864437)
AFM |
(Post 14858202)
Details please.
Originally Posted by Roelof
(Post 14864506)
It is simple to convert 7 ports into 5, just take out 2 bridges between ports.
(Post 15075933)
Details please.
With 7 port engines the ports close to the exhaust are very small: https://familyland.com.au/media/cata...rp_38571_1.jpg If you take out the bridge that is deviding the port next to it it will be one large port. Do it on both sides and 7 ports are now 5 ports. |
Are these the bridges to take out??
(Post 15075955)
2 ports next to each other are devided by a "bridge", remove the bridge and they will become one.
Also possible but then you will create a very large port making the sleeve weak.
One of these then. The right side of the pic is where the exhaust port is.
(Post 15076316)
nr2 bridge is the best choice
#2?
(Post 15076351)
| All times are GMT -7. It is currently 12:12 PM. |
