Go Back  R/C Tech Forums > General Forums > Nitro On-Road > Onroad Nitro Engine Zone
Rody VS Racing Engines - Onroad Motors >
Like Tree137Likes
Old 02-27-2017, 06:32 AM
  #16
Roelof's Avatar
If you can not run close to the same laptimes as the topdrivers, you do not have to focus on the engine bearings......
Last year I had to change the bearings of my Ielasi 9CL and placed standard steel bearings, the engine was still fast as before with ceramic.
TeamCarnage, Pooh2 and VS_Rody like this.
Roelof is online now
Old 02-27-2017, 10:38 AM
  #17
Raced the VSR02 this last weekend here in TX. Let me start with the end.... Awesome!! Managed 3'rd in B Main mostly sponsored pros ahead. Engine created some buzz at the track - everybody said they heard good things and were looking at the performance on track and these are guys who run at National level. As for engine - I'd say the major feeling is that it's very smooth, clearly massive bottom end but it doesn't hit you like the dump truck torque of a modified Mito 9... it is very controllable. Top end is ridiculous no effort to match any engine on straight. Two other major things - Temp and Mileage. Didn't need to push temp above 215 F for competition on 25% nitro yet it easily made 5 min heats. I think this engine has major potential!! Should I run at a little higher temp and on 30% maybe? Any suggestions would be welcome. Just as awesome as Rody RB .12 was a decade ago!!
Eghoop is offline
Old 02-27-2017, 11:07 AM
  #18
Ran VSR02 (MRX6)this weekend at Series race here in Texas. Created buzz at track lots of folks had heard good things about it. Motor ran really well - exceptional actually. Main feature is smoothness. Lots of bottom but not wild like a modified Mito long stroke. Top end very good - no issues on straight with anything & most of competitors are Nat'l level guys in US running "not slow" mills. 2 big things stand out temp and mileage. Never ran over 220 F on 25% and it lasted 5 mins easy. Think there is much more potential!! What temp should I aim for and should I run 30% for max power?
Thunderbunny likes this.
Eghoop is offline
Old 02-27-2017, 11:26 AM
  #19
1/8 IC Fan's Avatar
Trader Rating: 102 (100%+)
Where did you run at?
1/8 IC Fan is offline
Old 02-27-2017, 01:31 PM
  #20
R/C Tech Elite Member
VS_Rody's Avatar
No need to run the engines over 230F and no need to go higher then 30% nitro either. This will make the engine less efficient and you will loose in fuelmilage.
VS_Rody is offline
Old 02-27-2017, 04:13 PM
  #21
Gulfport Raceway - Mike's Hobby Shop Porter, TX
Eghoop is offline
Old 04-10-2017, 11:31 PM
  #22
Default Difference between 2069 and 2115
HI Rody,
It's nice to see you here.
May I know what's the difference between the 2069 and 2115 pipe (both used on your VS-R02)?
Thank you very much for your time.
Ted
Ted Su(TW) is offline
Old 04-11-2017, 12:36 AM
  #23
VS_Rody's Avatar
Originally Posted by Ted Su(TW)
HI Rody,
Ted
Hi ted,
The 2069 is more smooth and gives you a wider rpm range compared to the 2115 pipe which has a narrower rpm range but also more power.
As always the 2069 is better on fuel-consumption compared to the 2115.
We mainly use the M32 manifold with these pipes.
Hope this has helped you further.
jtrmx250 likes this.
VS_Rody is offline
Old 04-12-2017, 06:37 PM
  #24
Thank you for your fast reply.
I'm about to place an order from your website. Do you offer break-in service?
Originally Posted by VS_Rody
Hi ted,
Old 04-13-2017, 12:29 AM
  #25
VS_Rody's Avatar
Hi Ted,
Unfortunately not possible for now.
VS_Rody is offline
Old 04-15-2017, 02:23 PM
  #26
mustangkillaz's Avatar
Why no Nova based on road engines?
mustangkillaz is offline
Old 04-15-2017, 11:34 PM
  #27
VS_Rody's Avatar
I have had a long collaboration with Novarossi in the past and they produce excellent engines. But it was time for me to try with a different supplier.
VS_Rody is offline
Old 04-17-2017, 11:01 PM
  #28
choisan's Avatar
and using nova will be more pricy, isn't it?
choisan is offline
Old 04-18-2017, 12:04 AM
  #29
Roelof's Avatar
If a 35plus21 can be found for just 190 euro and a new JP engine based on the same 35+ for just 279 euro I think the price depends in which configuration and how much own rework you want.
OS has proven to make good engines and has many OEM customers...
Old 04-18-2017, 12:31 AM
  #30
VS_Rody's Avatar
As Roelof has stated, indeed it depends which configuration you are using. For our VS Racing engines we try to keep things as simple as possible.
VS_Rody is offline
