Go Back  R/C Tech Forums > General Forums > Nitro On-Road > Onroad Nitro Engine Zone
Rody VS Racing Engines - Onroad Motors >
Like Tree66Likes
Old 11-17-2017, 01:38 AM
  #166
VS_Rody's Avatar
The new VSR03 is now also available at Amain.
1/8 IC Fan likes this.
VS_Rody is offline
Old 11-18-2017, 12:19 PM
  #167
Presentation
Rody VSR03
AutoRCnewsModelisme - VS RACING VSR03 Nitro On Road Engine
1/8 IC Fan and VS_Rody like this.
Pedro Jesus is offline
Old 11-28-2017, 01:03 AM
  #168
I finally had a chance to run the VS2102 at our national championship. I ran 4 litres though the engine over the event and it ran faultlessly (as expected).
I tested both the Hipex and OS pipes and the OS pipe was a much better match for the track...it gave the engine significantly more top end - which I needed.
I'll be running VS engines for the 2018 season 💪💪💪
jtrmx250 is offline
Old 11-28-2017, 01:19 AM
  #169
VS_Rody's Avatar
Thank you for your update.
Can you also tell us what fuel you have been using and also its nitro %, just curiousity and information shared.
I suppose the Hipex pipe you tested was the EFRA2115
VS_Rody is offline
Old 11-28-2017, 02:48 AM
  #170
Yep, was the 2115.
I was running VP 25% nitro, 11% oil (though I add 1% caster so 12% total).
jtrmx250 is offline
Old 11-28-2017, 02:58 AM
  #171
VS_Rody's Avatar
Yep, was the 2115.
OK Thanks for the additional info.
Yes adding a little oil gives you a safer margin.
VS_Rody is offline
Old 12-20-2017, 10:53 AM
  #172
Rody, a question here related to the different models of engines from the primary manufacturers. I have found a GSR21.7R. Is that the same as the basic OS2103R engine? If there are differences, do know what they are and can explain them?
davidl is offline
Old 12-20-2017, 11:39 AM
  #173
VS_Rody's Avatar
Hi David,
Seems like an R2103 to me, same as the original version nothing more. you need to ask them what are the differences.
VS_Rody is offline
Old 12-20-2017, 04:07 PM
  #174
Hi David,
Thank you.
davidl is offline
Old 12-23-2017, 05:29 PM
  #175
1/8 IC Fan's Avatar
Trader Rating: 63 (98%+)
Rody,
Have you tested any of the Mielke Pipes by chance? I know between them and Hipex, they make many for others.
1/8 IC Fan is offline
Old 12-24-2017, 11:08 AM
  #176
VS_Rody's Avatar
Originally Posted by 1/8 IC Fan View Post
Rody,
We did a long time ago. The Mielke pipes are strong and rigid, they are manufactured in a different way. For me they perform the same in Off-Road use but never got them to perform enough in On-Road compared to the Hipex pipes.
VS_Rody is offline
Old 02-22-2018, 01:03 PM
  #177
VS_Rody's Avatar
Hi,
FYI we just released a new type of optional rear-cover for our VS Racing engines.
Developed by Rody Roem for VS Racing On-Road engines
This optional rear-cover made from 7075-T6 orange anodized has a specific shape to better guide the gases to backward lateral transfers in order to improve engine efficiency.
Compatible with engines: VSR01, VSR02, VSR03, VSM01, 2101R, 2102R, 2103R
More info here
VS_Rody is offline
Old 07-09-2018, 11:40 AM
  #178
hi rody just got my first vs02 after runing the os2102/2101
should i remove the 0.1mm shim for 16% nitro.and any tips to
smooth out the mid range torque but still keep good bottom end
only tryed the os pipe combo so fare
rick oxley is offline
Old 07-09-2018, 11:58 PM
  #179
VS_Rody's Avatar
Hi Rick,
No need to change anything on the VSR02 when using 16% nitro. If the track is short then you can try and take out 1 headshim of 0.1mm but keep an eye on the glowplug to be sure there is no deformation.
The OS 2080-SC is an excellent choice and is the same as the VS302098/M2001
VS_Rody is offline
Old 07-13-2018, 03:44 PM
  #180
ralphierace13's Avatar
my buddy ran your motor.21 last weekend at our local track I have one word, :" wow"!!!
ralphierace13 is offline
