Go Back  R/C Tech Forums > General Forums > Nitro On-Road > Onroad Nitro Engine Zone
Rody VS Racing Engines - Onroad Motors >
Like Tree138Likes
Old 10-31-2017, 03:26 AM
  #136
Default Break in
Rody which metod of break in you suggest for your engine?
Metrim is offline
Old 10-31-2017, 04:11 AM
  #137
Roelof's Avatar
With that question I also want to know how the EBIS engines were performing.
Roelof is offline
Old 10-31-2017, 05:27 AM
  #138
R/C Tech Elite Member
VS_Rody's Avatar
Hi Metrim/Roelof,
I can suggest you the EBIS system without any problems(available on our webshop).
I have run-in with the EBIS system several engines just before the 2017 Worlds in France and am happy with the results.
The performances are the same as we do with the old-school method but the first start and finalizing of the running-in are much more comfortable and for sure less stress on the engines. So I can validate this system.
On a technical point of view. When using this system the piston is adapting itself to the sleeve and you get a nice finish on the part of the piston which is in contact with the sleeve.
However the chrome of the sleeve is not behaving the same as that when the engine is being used. Once you start the engine and you get a real combustion inside the engine(and so temperature fluctuations) the chrome is also adapting on the piston.
I have kept an eye on several engines and checked them frequently and find that the piston/sleeves have a better look then while using the old-school method where the risk of gripping is a little higher then when using the EBIS system. So for sure for the less experienced racers this is a good thing.
Of course this does not mean that you can start the engine and start over-revving it and squeeze all the power out of it immediately.
Hope this has helped you further.
VS_Rody is offline
Old 10-31-2017, 06:06 AM
  #139
Interesting, has any test been done to compare the EBIS with lapping?
NitroVein is offline
Old 10-31-2017, 06:33 AM
  #140
VS_Rody's Avatar
Hi NitroVein,
Please be more explicit with what you mean with lapping?
VS_Rody is offline
Old 10-31-2017, 07:33 AM
  #141
Originally Posted by VS_Rody
Hi NitroVein,
Using lapping compound between piston/sleeve to mate the surfaces better before break in.
Old 10-31-2017, 08:03 AM
  #142
VS_Rody's Avatar
This is way less accurate because you will not know how much you will take off the piston when lapping, plus you need to clean very very well after this otherwise the piston/sleeve will continue to wear.
Surely not advised for me.
VS_Rody is offline
Old 10-31-2017, 09:01 AM
  #143
Okay, good to know!
I guess if you know how tight it should be, you should be able to stop the lapping in time. But most compounds are harder then the aluminium, so getting that right and cleaning well after would be critical.
I'll stick to regular break in!
VS_Rody likes this.
Old 11-02-2017, 09:44 PM
  #144
snuvet75's Avatar
Trader Rating: 16 (94%+)
Hi Metrim/Roelof,
Hello Rody. Can you explain a bit more on how EBIS system works? Like how the engine will be started, what other equipment is needed and how long it takes, etc.. Thanks.
snuvet75 is offline
Old 11-02-2017, 10:53 PM
  #145
Engine break in with these motors is not a process of metal removal.
It is a process whereby the sleeve is stretched into a barrel shape according to the temperature profile from top to bottom. The sealing ring around the piston is just honed by the process.
To prove this to yourself, you can refresh a sleeve where the piston is not shot by heating it (the sleeve) in an oven on max temp for 20-30 minutes or so and then letting it cool.
The sleeve relaxes and recovers somewhat. Often the motor performs even better than new after this.
Or you can just mic the sleeve o.d. before and after break in.
JTeamtech is offline
Old 11-03-2017, 01:56 AM
  #146
VS_Rody's Avatar
EBIS= Easy Break In System
It's a device where we install the engine(without the cooling-head, combustion chamber) and then fill it with oil.
Heat up the oil until around 90C then the engine will be rotated with an electric stepper motor for about 4H
We call this pre-running and we offer this possibility when you purchase an engine on our website.
Then when you receive the engine you can start it like a normal engine, just follow the procedure:
A Pre-Run engine allows easier starting once it is assembled in your car. It is however still advised to pre-heat your engine before each start. So you do not put too much stress on the conrod and to have a piston/sleeve assembly well dilated.
For the VS Racing engines who are pre-run with this system.
Before starting, pre-heat the engine.
When you have started the engine let it idle for 1/2 a tank.
Let it cool down.
Then start the engine again and on the track start setting the engine to its final setting over 4-tanks starting on the rich side and gradually going leaner untill you have reached maximum power at the end of the 4th tank.
You can find more info HERE
VS_Rody is offline
Old 11-03-2017, 04:04 AM
  #147
Roelof's Avatar
Richard (the guy from EBIS) and I have started our builds at the same time after some talks of how to do it. He made his EBIS and and I my own based on stuff I had lying arround. You can read the build, the results and the discussions here:
http://www.rctech.net/forum/onroad-n...h-machine.html
Roelof is offline
Old 11-03-2017, 04:54 PM
  #148
never heard of this before does this work when the engine has lost some
compresion instead of a liner pinch?
rick oxley is offline
Old 11-03-2017, 06:14 PM
  #149
snuvet75's Avatar
Let it cool down.
Yeah I read that in your web last night and thought it didn't make any sense that EBIS is only $60 to purchase. It looked just a little bit more expensive than $60. Didn't read the "Pre-Run Service" part. LOL
snuvet75 is offline
Old 11-03-2017, 08:23 PM
  #150
ralphierace13's Avatar
Let it cool down.
rody when u say finish the process over the next 4 tanks, do u mean 4 tanks in a row or cooling in between each tank then reheating and starting?
ralphierace13 is offline
