Old 09-20-2006, 05:39 PM   #61
mugenb46's Avatar
it's more so the piston to the sleeve
mugenb46 is offline   Reply With Quote
Old 09-21-2006, 07:40 AM   #62
Corse-R's Avatar
Originally Posted by German Muscle
you cant fully balance a single cylinder engine. Just a FYI
I repeated this until I get hasted of saying it... now, simply I promised to myself to not repeat this phrase. The unique advice I say is to not leave any engine on the hands of someone he's capable of balancing a 1 cilinder engine. because is impossible.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 09-21-2006, 09:41 AM   #63
EdwardN's Avatar
Originally Posted by mugenb46
war mac i'm going to build a balencer and i will post it when i'm done. maybe someone can tell me if i did it right, after i spend 20 hours on it lol
I can sugest you take one of old crancase which you are not going to use, cut it I showed on attached pic, then install new bearings, make sure you don't lubricate them while you balance your work ( then for storage better to lubricate), now you can do your balancing work easier.
DISCLAIMER: Since 90% of my posts may be BS, and since my posts may be either insanely idiotic, incoherent, and/or not even close to a rational thought, please accord my posts no more than 10% of credibility.
EdwardN is offline   Reply With Quote
Old 09-21-2006, 10:05 AM   #64
EdwardN's Avatar
Alfonso, it is impossible to do perfect balancing, but it is possible to come pretty close, specialy when we know our usefull range of RPM (when motor is loaded) is pretty narow-between 26K RPM and 42 K RPM. Yes there is very good balancing numbers which make big difference. Just look any of performace 21 engines-they have tungsten inserts on counter weight-this is done to improve balancing. There are many different ways to improve balancing just need to get hands on it.
Old 09-21-2006, 08:20 PM   #65
mugenb46's Avatar
thanks dude, cool to see that
Old 09-22-2006, 01:24 PM   #66
Warmac's Avatar
Send a message via MSN to Warmac
EdwardN: nice idea, limited machining, good precision.
mugenb46: I guess we are one step closer now.
Warmac is offline   Reply With Quote
Old 09-22-2006, 02:14 PM   #67
German Muscle's Avatar
when you balance these motors for an RPM its balanced.....for that RPM. So if you balance it at 38,000 RPM then it will only be in blance there and out of balance everywhere else, you cant balance these motors for a RPM Spectrum. Its a set RPM area as in 1-2K RPM, not 20K. You absolutely can not balance these engines any further than that. Ive seen modders engines vibrate worse on a dyno than stock....and they claimed to fully balance the crankshaft, ive also seen other modders engines act like stock, no one is balancing them, they may put it on a machine that spins it and say the balance it, but its a big BS fest as far as that goes. Trying to balance these engines is a waste of time and money as you cant do it.
German Muscle is offline   Reply With Quote
Old 09-22-2006, 08:53 PM   #68
mugenb46's Avatar
that makes all the sence in the world to me, dammit i'm pissed thats it i quit lol. but how does it get out of balence from one rpm to another, or is it a harmonic balence, that i know some shit about. when you run 30,000 dollar motors in cup and arca cars they have a range were they perform in the perfect balence around 9000 to 9800 rpm this is short track rpm 6500 to 7500 rpm talledaga or daytona the motor is not in it's harmonic balence range. because of the gear they make us pull
Old 09-22-2006, 09:57 PM   #69
yes im pretty sure its harmonic balancing done at the factory, EB Mods claims to balance his this way but its a flat out lie.
Old 09-22-2006, 10:23 PM   #70
EdwardN's Avatar
I am not going to argue with you. You might be right-I don't know on what info you base. I know what we are doing and how we are checking if it is pretty much balanced. On RC cars you can't really feel it-you are far away from thr car and it is moving fast, so there is no way to check it, but I will get back to where I came from, when you fly control line airplane and engine is not balanced then you feel itching on the control line handle. If somebody fly control line airplanes they will know what I am talking about. So we do make design, try it on airplanes, on different range of RPM (Please don't ask how we mesure it-we have way up to 10 RPM accuracy), Then change design and fly again, and agian and again, after couple of tens samles collected, just make analizes and it is pretty much fit to certain system, which just use common sence can be converted to formula.. Then, just one more time control test and it is ready to go. This is the way how we came to the cut on the pic. Sorry for quality of pic, but this the best I could do.
I am leaiving this up to you to make judjemnt-if we are doing balancing right or no-you can call it BS, or whatever, it is not really bothering me. I know what we are doing and I know phisical results. Balancing can be done very good and averaged to very wide RPM range. We fly on from 25 K to 42 K and it makes a lot of difference compare to regularly static balanced. We tryed all kind of engines, with all kind of modding. No how much difference it is on performance-this is triky question_ i will leav it up to you to decide. If you want to know more obout this talk to Matkemiers brothers-they are really know balancing and they are the mentors on balancing for a lot of engine designers.
Old 09-22-2006, 10:48 PM   #71
Who are you? someone from Axial? All of my information was from Brian Kenny @ Nitrodyne Systems AKA mxwrench on here.
Old 09-22-2006, 11:01 PM   #72
EdwardN's Avatar
I am just the guy, who is messing with nitro engines since 1976. Learn here, there, you know how it is happened. I know Brian Kinney very well-he is one of my best friends.
And brian info is absolutly correct we did discause with him this many times, but the difference is that our aplication is slightly different to what you try to bring as sample-motorcycle, so it is different leverages on cranck, diffrent RPM, different ratio HP/capacity etc. In motorsport they develope a lot of really good thing, actauly most o it, but all of them just simply can't be transfered to niro engines.So if any time something is taking from motrsport-there is defenetly need corection to fit our needs in RC
Old 09-23-2006, 10:45 AM   #73
tl2111's Avatar
Trader Rating: 21 (100%+)
Send a message via MSN to tl2111
LOL, he is the Designer of Axial engine..
BTW, how u going Ed? drop me a PM or Email if you have time
Tommy
*Tourer**Futaba***SpeedPassion
*F1**4PX***TORO
*12th**4PX***TORO
*8th**4PX***OS Speed XZ-R
*10th**4PX***OS Speed XZ
tl2111 is offline   Reply With Quote
Old 09-23-2006, 01:43 PM   #74
Tommy
figures, i dunno why he couldnt say that tho.
Old 09-23-2006, 01:52 PM   #75
He should'nt have too...
RC_Alan
rc_alan is offline   Reply With Quote
Engine Mods Omar Onroad Nitro Engine Zone 208 02-11-2007 04:06 PM
engine mods rjmods.net Web Links 2 12-22-2006 01:54 AM
ENGINE MODS? zrchobbies Electric Off-Road 11 08-29-2006 02:21 AM
Need some help with engine mods...... jamiekulhanek Onroad Nitro Engine Zone 6 08-22-2004 11:23 AM
F/S or F/T - Kyosho V1R with RB X12 engine and mods dg2b R/C Items: For Sale/Trade 0 02-21-2003 06:41 PM
