Pipe and manifold... how to choose
Hi, I have been reading about it, and almost concord about the size of the track you are running in, small, medium or large.... but how to know this range...
Our track has the main straight about 60mts. and take about 18.5-19sec. to complete a Lap... how you measure the size?? to choose the correct combination of pipe and manifold... (ON ROAD) thx fot the advise... |
All engine manufacturers have their pipe selection for their engine models, and also a selection oh headers in different sizes. Basically they have pipes which enhance low end power (torque) and others which enhance high end power (high RPM), and different lenght headers (shorter= more RPM, Longer = more Torque). So if your track is tight and twisty you´ll probably best suited with a torquier pipe, and if it is a fast flowing track where you are at the gas most of the time, you are better with an RPM pipe...if it is a mixture between fast and tight and you´ll probably need the rpm pipe with a médium or long header.
By the way waht engine do you have? is it 1/10 or 1/8th On Road?? AFM |
thx AFM, I am running 1/10 Serpent 748TQ, with the Novarossi .12 ISON...
And I was looking for the REDS Pipe 1974, and S Manifold... but may be is better Medium... |
Originally Posted by Byronf1
(Post 14533022)
Originally Posted by afm
(Post 14532832)
Originally Posted by nitrodude
(Post 14533042)
Reds is based on a Picco. Find a novarossi pipe
(Post 14533022)
And I was looking for the REDS Pipe 1974, and S Manifold... but may be is better Medium... And get the short header http://www.novarossidirect.com/41615_p_2640.html And the medium header http://www.novarossidirect.com/41616_p_2641.html And the long header http://www.novarossidirect.com/41617_p_2642.html With all thse you are set for any track. Regards AFM |
thank you !!!
| All times are GMT -7. It is currently 11:05 PM. |
