Old 11-26-2005, 07:12 AM   #1
noddy's Avatar
Default Fuel Percentages
People,
I'm just trying to figure out what the optimum nitro/oil percentages for the not-so-sunny UK are. Running an 18ss with an O'Donnell 077 in fairly damp conditions (most of the time). Generally fairly low baro pressure (less than 29.92 or 1013mb) and purely used for bashing off road.
And if I could be so bold as to sneak in an extra - expecting delivery of Hellfire K4.6 High Output in January... Any idea what will be opti percentages given the above conditions?
Sorry if this sounds thick - still trying to figure out what it all means!
noddy is offline   Reply With Quote
Old 11-27-2005, 02:31 PM   #2
noddy's Avatar
Okay..... so not much of a response! How about a different tact - I assume different plugs work better or worse with different fuels and different weather conditions. Given the previously posted weather (damp, low pressure) can anybody recommend an optimum setup?
Please?
Anyone??
I'll get my coat.
Old 11-30-2005, 04:59 AM   #3
wat is your question?
generally racers use 10% oil and either 25% or 20% nitro. i prefer hotter plugs as it helps it idle better.
Doomah is offline   Reply With Quote
Old 11-30-2005, 01:25 PM   #4
noddy's Avatar
Thanks Doomah
I guess the question is whether or not people use differing fuel percentages or plug types with different weather conditions/barometric pressures to give optimum performance. Hotter plugs for better idling is a start.
People spend vast amounts of money on their engines and the tiniest performance enhancing techniques, and spend hours trying to fine tune the little suckers and this just seemed like another area to look at. I don't race, I build and bash for fun. But in the colder and wetter days, I like to look at ways I can improve the overall package. As there are so many different fuels etc out there, I wondered if it was a feature in racing.
Old 11-30-2005, 04:01 PM   #5
ok, here is a link that will help you choose what plug you run depending on what %nitro u use and the weather temp.... a 5plug (hot) seems the go for you.... the od77 is a hot/warm plug, so your in the ball park.
http://www.rbproducts.com/mainEn.php...ght%20glowplug
Old 11-30-2005, 04:44 PM   #6
noddy's Avatar
Thank you very much for that. That's exactly what I was looking for.
Cheers blue
Nitro Percentages and what to run in a os .12 cv-r Tune71 Nitro Off-Road 6 10-18-2007 04:48 PM
Nitro Fuel Percentages for .12 Engines Jerseyboy Onroad Nitro Engine Zone 5 06-14-2007 05:01 AM
DIFFERENCE BETWEEN NITRO PERCENTAGES? pcr2nv Electric Off-Road 12 12-22-2005 06:41 AM
Does O'Donnell fuel make a huge accel. gain on HPI fuel Smoke21 Nitro On-Road 3 05-03-2004 05:44 PM
Lubrication percentages in nitro fuels huasze Singapore R/C Racers 2 06-27-2002 11:10 AM
