Go Back  R/C Tech Forums > General Forums > Nitro On-Road > Onroad Nitro Engine Zone
Engines leans down a lot once tank gets to 1/4 full >
Old 12-21-2005, 05:24 PM
  #16
SpeedBump57's Avatar
In his frist post he stated he already did that!
SpeedBump57 is offline
Old 12-24-2005, 02:44 AM
  #17
rcfoolz's Avatar
Trader Rating: 22 (100%+)
one more thing to check. when the tank gets to about 1/4 left, is your fuel foaming/bubbling? You might have the screws too tight holding the tank in and not letting the rubber groments absorbe the vibrations.
rcfoolz is offline
Old 12-31-2005, 07:57 AM
  #18
WeatherB's Avatar
Thanks for all the help... The problem turned out to be a tuning issue. My high end was too lean and the low end too rich.
WeatherB is offline
Old 01-22-2006, 01:12 AM
  #19
gilanson's Avatar
got same experience.... so which needle did you adjust
gilanson is offline
Old 02-10-2006, 08:47 PM
  #20
GregH's Avatar
hopefully both from what I was reading at the start of this thread.
GregH is offline
Old 02-16-2006, 03:11 PM
  #21
Tabushi's Avatar
I just had the same problem on my TNX Pro Monster Truck ... and the solution was to use a loooonger presure line ... now i have the same engine behaviour during the entire tank ... just a "tad" lean when its almost dry (just the smell of fuel in the tank and fuel mainly on the tubing) but thats normal ...
Tabushi is offline
Old 02-16-2006, 09:11 PM
  #22
I have the same issue. I have 5-1/2 inches of line from the tank to the carb. I have a fuel filter. I have not yet replaced the tank. I keep messing with the low and high speed needles, but I'm not getting anywhere. UGH!!!!
I do get smoke coming from my fuel tank when I open it, though.
sstupid is offline
Old 02-17-2006, 02:08 AM
  #23
That's just exhaust gas,nothing to worry about.
Allan
Allan is offline
Old 02-17-2006, 07:07 AM
  #24
gilanson's Avatar
so how long (in inches) is your pressure line now need to try that too
gilanson is offline
Old 02-17-2006, 11:35 AM
  #25
So, what are the recommended lengths for:
1) Pressure line
2) Feed line?
Thanks.
sstupid is offline
Old 03-09-2006, 05:56 PM
  #26
Talking
The pressure line and the feed line should be within 1/2 an inch length of each other. I find that a slightly longer feed line works well, but you will have to prime fuel into the line before the beast will kick over.
Also, a tip I have found very usefull, is to ensure you allow the petty lid to "SNAP" shut, as if this is not AIRTIGHT, pressure will fail to build inside the tank.
Sargios is offline
