Go Back  R/C Tech Forums > General Forums > Nitro On-Road > Onroad Nitro Engine Zone
Project: Break in Dutch machine >
Like Tree19Likes
Old 05-15-2017, 03:42 PM
  #151
Roelof's Avatar
The Shell 0w20 I use is simple motor oil, just use some brake cleaner to flush out some oil and re-oil the bearings and crankpin with afterrun oil. But to be honest it is not really needed. I also have put the engine together w/o any cleaning and it was startable.
Roelof is offline
Old 07-04-2017, 03:42 PM
  #152
How do I order one of these?
Any help would be much appreciated
mugengreg is offline
Old 07-05-2017, 01:34 AM
  #153
Roelof's Avatar
I do not sell them, The EBIS can be purchased at RichardE on this forum.
Roelof is offline
Old 07-26-2017, 02:33 AM
  #154
Default Knur600
My toy.
;D
Project: Break in Dutch machine-knur600.jpg
arduino with:
- PID for heater,
- hall for rpms,
- some logics inside code.
12Volt overall, max 9A consume for heater, then adter 15 minutes less
desotoracing likes this.
M.Abramowicz is offline
Old 08-20-2017, 09:35 AM
  #155
Does anybody know the distance from the motor mount to the center of the crankshaft on a novarossi .21? Also, does the engine need heaters on the sleeve, or without heaters its ok?
Thinking about building one of these
nitrodude is offline
Old 08-22-2017, 01:50 PM
  #156
Roelof's Avatar
The center of the crankshaft is 0.5mm above the engine mount. Picco seems to be on the mount. I made spacers for 0 and +0.5mm
Heaters on the sleeve is not needed but when using cartridge heaters it is adviseable to mount them on a kind of heatsink with the temperature sensor of the controler with it so the heat is well spread and the sensor is reading right. You only have to wait longer to get the oil well heated.
Roelof is offline
Old 01-08-2018, 11:53 AM
  #157
What would I use to control the temperature of the thermocouple? And what about a temperature read out?
Old 01-08-2018, 12:55 PM
  #158
Roelof's Avatar
Ebay, Alixpress an even DX.com you can find many temperature controlers. Mine can go up to 115 degees C what is enough but has no housing or frot panel, but it works for just 7 dollar.
Roelof is offline
Old 01-08-2018, 02:10 PM
  #159
https://www.ebay.com/itm/10A-110V-Di...wAAOSw-ldZacZJ
Something like that?
Old 01-08-2018, 02:45 PM
  #160
Roelof's Avatar
Yes. As I can see on the housing the output is not realy an output but a relais switch (as most of them are), the manual will explain how to wire the heaters.
Roelof is offline
Old 01-08-2018, 03:15 PM
  #161
How do I power everything? I will install a amp readout as well.
Do I need a circuit board connected to a power supply? I will build as 12v.
Old 01-08-2018, 04:23 PM
  #162
Roelof's Avatar
If you want to make it work on 12v you better get a 12v version of the temp controler.
With every device you get a manual how to connet but there are 3 devices to connect to the 12v:
12v - power switch - amp meter - motor
12v - temp controler - temp sensor hanging in the oil.
12v - power switch - relais switch from temp controler - heater.
It is wise to mount the temp sensor and the heaters to the same aluminium surface so the sensor does sense the heater very well. If they are mounted apart from each other then (for sure with cartridge heaters) the heater will shoot into a high temperature causing burning oil arround it before the sensor will sense the heat.
Roelof is offline
Old 01-08-2018, 08:59 PM
  #163
Originally Posted by Roelof
The controler on the internal side wired:
And it works.
This is what scares me, as I know nothing about electronics. Im a machinist by trade and have access to high end equipment, thats the easy part
Old 01-09-2018, 01:59 AM
  #164
Why are you trying to control the temperature of the thermocouple? A thermocouple is a measuring device made up of 2 dissimilar metals used to measure temperature. The 2 wires are welded together and when a change of temperature occurs it creates a voltage that is then measured and depending upon the types of metals used you can then compare that voltage to a known standard and determine the voltage.
faqcya is offline
Old 01-09-2018, 03:00 AM
  #165
Roelof's Avatar
Ofcourse, remember that it is also equipped with a rpm control and read out. When using a simple geared motor with approx 400rpm output there is no need for a rpm control and readout.
In the attachement a simple diagram
Attached Thumbnails Project: Break in Dutch machine-breakin.jpg
Roelof is offline
