Go Back  R/C Tech Forums > General Forums > Nitro On-Road > Onroad Nitro Engine Zone
What is this cylinder sleeve coated with? > What is this cylinder sleeve coated with?
Old 11-07-2015, 06:10 PM
fyrstormer's Avatar
Default What is this cylinder sleeve coated with?
It doesn't look like my other ABC cylinder sleeves. Any idea?
fyrstormer is offline
Old 11-07-2015, 07:05 PM
What engine is it from
Giant655 is offline
wingracer's Avatar
Trader Rating: 24 (100%+)
Looks like nickel. Probably an old ABN motor (Aluminum piston, Brass sleeve, Nickel coated).
wingracer is offline
Old 11-07-2015, 11:51 PM
fyrstormer's Avatar
It's from an HPI Nitro Star .12R SS.
It doesn't look like nickel plating. I own a couple nickel-plated items and it looks shinier than this when polished, and when tarnished it has a distinctly brown color whereas this looks grey with the slightest hint of purple. (my camera didn't do a good job of showing that.) Also, I have the engine and a spare cylinder for it, and they both look exactly the same, which says to me that the current color is not the result of tarnish, because if it were there would be some amount of variation between the two.
That's not to say it isn't nickel-plated, it just doesn't look like I would expect nickel-plating to look.
Old 11-07-2015, 11:53 PM
fyrstormer's Avatar
Hmm. Now that someone mentioned nickel-plating, I thought to search for that term, and it turns out it's actually a nickel-silicon-carbide coating. Man, I bet that stuff takes a long time to wear down.
http://www.angelfire.com/falcon/hpi_...st_engines.htm
Old 11-08-2015, 12:22 AM
Roelof's Avatar
It is called Nicacil and it is not that strong compared with Chrome. Nicacil has a lower friction and should be a better choice but for our pistonring less engines it is too fragile
Roelof is offline
Old 11-08-2015, 04:16 AM
fyrstormer's Avatar
Ah. Hmm. Well, at least the coating has no edges where it can start to chip off. I guess we'll see how it holds up.
Old 11-09-2015, 12:18 AM
banana rt's Avatar
it will peeled off easily, compared with chrome one
banana rt is offline
Old 11-21-2015, 06:14 PM
Suspended
Good to know.....
bertrandsv87 is offline
Old 12-20-2015, 01:46 AM
fyrstormer's Avatar
Interesting tidbit from an archived copy of the HPI FAQ:
"The new coating and the use of an oil ring in these engines means that they feel as though they have low compression when there is no fuel in the engine. When a compression gauge is put on these engines, it will only register 40-50 psi. However, when oil is added to the engine so that the oil ring is filled the compression will jump up to 65+ psi. We are having a number of these engine sent in (about 3-4 per week) where the customer is reporting that the engine has no compression. When we test them, we find that the compression is well within tolerances and that when the engine is ran, it shows no sign of having a worn piston and sleeve. In addition, the coating on the sleeve has a silicon coating that makes it more slippery than chrome, so it doesn't feel like it has as much 'pop' even though the compression is still good."
