Ofna remote igniter
How do install the ofna remote igniter.there is the main red wire and then a black ground.do I ground out to motor mount then to igniter?
only works with Starter Boxes
http://www.ebay.com/itm/291186759689...%3AMEBIDX%3AIT
It's one of these Not sure how to add a link:confused: |
Where ever its accessed to you on a aluminum chassis, maybe somewhere toward the rear of vehicle. Too many connection to GP Wouldnt mess with it. To each his own. Gadget's.
Yea I wouldn't normally but this is a nitro sprint car for dirt oval so its a pain taking the wing on and off to start it
The wire with the eyelets is attached to the engine pad using the engine mounting screw on one end, the other end is attached the the glow adapter bracket mounting screw.
I did post Where you have access to it.
