Old 02-20-2007, 03:58 PM   #76
Trader Rating: 13 (93%+)
Since having the engine modified it has huge top end now compared to before.. (thank you mark from massive mods)
the engine was fast on the weekend just the pickup was a bit slow..next meeting im going to try a shorter 1st gear in my mugen mrx4 and see how it goes.
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 02-20-2007, 08:14 PM   #77
Super Moderator
Snowy's Avatar
Trader Rating: 14 (100%+)
Originally Posted by mrgsr
This engine has no bottom end wat so ever! slow..
is this normal guys?
It could be your clutch setup John. Get J spec Jay to have a look at it, as he is an expert now.
Racing Lines Magazine
Snowy is offline   Reply With Quote
Old 02-20-2007, 08:45 PM   #78
thanks Snowy
yeh its already been j-spec'd
i lost a thrust bearing in the 2nd qualifier and then jay had a look at the clutch setup again. the manual says to set theclutch nut to 1.2mm. I am at 1.4mm now so i might hav eto go tighter..
Old 02-21-2007, 11:33 PM   #79
vti-chris's Avatar
What's the top end on this engine compared to low rpm torque off road engines?
Won't the high revs cause premature wear on it compared to low rpm engines?
vti-chris is offline   Reply With Quote
Old 02-25-2007, 07:00 PM   #80
Default low end tuning..
hi guys
from the factory low end setting are you tuning the bottom end richer or leaner?
im trying to get more bottom end from the engine but my low end has been tuned richer from standard. the top end is great and it blow a little smoke from the exhaust with the plug a bit wet after each run.
Old 03-12-2007, 01:42 AM   #81
vti-chris's Avatar
Anybody knows the differences between the older vz-r and the ver II model?
I tried the parts list on O.S. site and it seems that the only ver II parts on it it's the crankcase and outer head.
osengines.com
If there are no other modifications on the ver. II why did they came up with it?
Old 03-12-2007, 01:49 AM   #82
i heard they made some internal case modifications to make it go faster
Old 03-12-2007, 03:31 AM   #83
vti-chris's Avatar
They use the same case as the v-spec but i was wondering how much difference will the case mods make?
I mean the older vz-r was an average motor and for the ver.II they say it's much more powerful.
Are these just illusions?
Old 03-12-2007, 03:36 AM   #84
i still believe its an average motor till i had massive mods modify it now it screams! and just keeps revving down the straight where it died out before
Old 03-12-2007, 06:11 PM   #85
graphiteman's Avatar
Default OS VZ-R II
There is a difference between the cranks on the first version and the verion II. I think it helped performance, and yes, it is noticeable.
graphiteman is offline   Reply With Quote
Old 08-10-2007, 12:27 AM   #86
vti-chris's Avatar
Looking to get more runtime out of my VZ-r ver.II.
I used the T2060SC tuned pipe but didn't work well...good power but sucked on fuel efficiency.
JP-1 worked OK and gave me more than a min runtime...from 6 went to 7+.
Novarossi 9901 about the same as the JP-1
I use the engine for off-road racing and it doesn't lack on bottom end at all.
I installed 1.1 springs with teflon shoes and it works great.Low to top this engines can put out some power!!
My only problem is the runtime...WANT MORE
Old 03-04-2008, 09:13 PM   #87
DogboneS's Avatar
Trader Rating: 20 (100%+)
Resurecreting a dead thread here. Has anyone seen or heard about a new OS on-road mill? After seeing the O.S. Speed buggy motors, I was wondering if the balanced crank and updated rod are going to pop up in a updated VZ-R. Now that Mugen is having their motors built by O.S., it would be a good time to update the on-road mill, maybe even under the Mugen name.
DogboneS is offline   Reply With Quote
Old 03-16-2008, 03:17 PM   #88
gearhead_22's Avatar
Send a message via AIM to gearhead_22
Default os vzr2
I have one and i only run 20% . I see that It has 2 shims under the head should I leave in both or take out one?
serpent sdx4 srx2 977WC-novarossi-748TQ
serpent S120 LTR-S411
serpent America/Ashford Hobby/skyrocket racing
Juwan Hunter
gearhead_22 is offline   Reply With Quote
Old 03-16-2008, 08:02 PM   #89
asw7576's Avatar
I put all the shims, and use 25% nitro ( close to sea level, humid and hot, about 33C to 35C )
I also use this on-road engine for off road , no problem.
Old 03-26-2008, 09:09 PM   #90
Woodlands Racer's Avatar
Thanks for the resurrection of the thread.
I too have the new VZ-R Ver. II and run it in my MRX4-R. Down here in TX, we run a Spec series for the 1/8th on-road class and the VZ is one of the accepted engines. Our first race was rained out and we are scheduled to run this weekend. Throughout the break in period and some practice time on our track it has been a solid engine. This weekend is going to be the BIG test though. We are hosting a well known annual race , the Gulf Coast/Speedline Grand Prix, and we have 3 qualifiers on FRI, 3 more on SAT, then the mains on SUN. I bought a spare conrod when I got the engine - hope to leave it in the bag. I have been running Rocket Science 30% Nitro content in the VZ. Used the same fuel for break in using a ten tank system and did it in stock condition without additional shims to what was already in place. I have found the VZ to be an easy engine to tune. I also run an INS box and I have gotten extended run time. I hope to pit in the six minute plus range.
Let's keep this thread going and help each other with tips on this engine. Looking forward to any one's feedback.
Roger
Woodlands Racer is offline   Reply With Quote
O.S VZR Version II .21 onroad Engine $75 Rock Racing R/C Items: For Sale/Trade 3 01-24-2007 11:18 PM
RC10GT Team version with engine, pipe and lots of extras Weez R/C Items: For Sale/Trade 6 12-08-2006 07:51 AM
OS VZR .21 version 2 Engine - PROFESSIONALLY MODIFIED - LIKE NEW!! j000sh Australia For Sale/Trade 1 10-16-2006 03:29 AM
REX ENGINE & M8 Version For Sales! idemitsu R/C Items: For Sale/Trade 2 01-17-2006 07:44 AM
REX ENGINE & M8 Version For Sales! idemitsu Singapore R/C Racers 0 01-17-2006 06:12 AM
