Old 05-27-2008, 12:28 AM   #46
Gseventeen's Avatar
Originally Posted by Qlone View Post
No, it was the normal bearing that came with the engine.
The only real maintenance the engine had needed so far was a new conrod. Everything else was still in (near) perfect condition...
What fuel do you run? and do you always run fuel out of motor before after
run is used?
NEW CAR (watch this space) POWER:NOVA 353 TUNED, JP BLACK MODDED,OS SPEC11
SPONSOR= EDV ELECTRICAL!! 9699-9961
'' THE LAD COMING BACK SOON!!!!
Gseventeen is offline   Reply With Quote
Old 06-10-2008, 05:53 PM   #47
Water does not compress, and something has to give, the rod is bushed and all of the pressure then ends up on a roller
If the manufacturers would use a roller bearing with out a retainer instead of a ball with a retainer they would never wear out
The bearing inside diameter would be larger so the crank could be larger and therefore the amount of air flow could be increased !!
Uhh, Never mind .... Where is that number to Boca ??
Crashtopher is offline   Reply With Quote
Orion Wasp Pro .28 engine .... would be a great truggy engine ... F/S... tradhunt R/C Items: For Sale/Trade 7 08-07-2007 12:56 PM
GO 28R/Full Starter Engine GRracing Ver.Team Fully Modified Engine handpiece Onroad Nitro Engine Zone 0 07-28-2007 03:42 AM
Ofna Picco .21B 3 Port engine, good budget engine Cain Electric Off-Road 1 03-26-2007 08:32 AM
selling custom savage roller with engine, truck zillia modded engine.$275 pat360xboxhalo3 R/C Items: For Sale/Trade 2 01-11-2007 05:23 AM
Engine Temperatures for Break-In and Normal Use for XTM 24.7 Engine. Head Shims? racer rich Nitro On-Road 0 12-13-2002 11:49 PM
