-   Onroad Nitro Engine Zone (https://www.rctech.net/forum/onroad-nitro-engine-zone-71/)
-   -   carby maintance questions (https://www.rctech.net/forum/onroad-nitro-engine-zone/86010-carby-maintance-questions.html)
BrainTeased 10-03-2005 03:41 AM
Hey guys
was wondering if you guys ever pull out your carbies regularly to replace the o ring seals on the mixture screws. I am currently suspecting that my mixture screws are unscrewing on their own ... and suspect that i damaged the seals when i was cleaning my engine i used engine degreaser (the automotive trade cans) and since at the time i did not have access to a air compressor i had to resort to leaving it in the sun to dry along with my chassis. Whats your thoughts?
mxwrench 10-03-2005 10:03 AM
Brain Teased,
I usually replace the orings in my engines once a season, but it depends on the use of the engine. Also if you spend alot of time tweaking the adj. screws it is possible for the o-rings to tear.
If your adj. screws wander from vibration, then I would say you definitly need to change your o-rings. Just be sure to put a little oil on them when you install them so they have a little lube going back in or you might catch the o-ring and tear it.
BK
RC Paperboy 10-03-2005 02:34 PM
Who makes replacement Orings for a novarossi carb? I cant seem to find a part number or listing on teh novarossi site.
BrainTeased 10-04-2005 03:56 AM
Originally Posted by mxwrench
Brain Teased,
BK
thanks BK
yea ill have a go at it and hopefully ill learn something new :)
RC paper boy
your best bet would be going to a automotive parts shop and asking them for a o ring seal kit. which will include all sorts of sizes including your fuel tank lid etc.. :)
