Old 04-04-2010, 03:47 PM   #271
GMartinez's Avatar
Trader Rating: 85 (100%+)
Originally Posted by stefan View Post
Would anybody know which Novarossi crankcase the XL7 is based on.
My sons crankcase broke in an unlucky crash and the original Max case is very expensive.
Thanks.
I believe it is based off the Kangaroo WCRX21
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 04-04-2010, 07:36 PM   #272
Trader Rating: 4 (83%+)
Thanks.
i believe the crankcase from the Novarossi RX21WC is the same as the Max XL7, but its going to cost you the about the same as the Max look into it before doing anything,my suggestion.
Shepherd Micro Racing @ Novarossi @ Matrix Tires @ VP Fuels @ Nugget Racing
Roniel_R is offline   Reply With Quote
Old 04-11-2010, 04:15 AM   #273
Kodak Hodak's Avatar
Send a message via MSN to Kodak Hodak Send a message via Yahoo to Kodak Hodak Send a message via Skype™ to Kodak Hodak
Hey Guys,
Got a MAX POWER .21 XLTQ and i NEED URGENT to know what the MAX POWER is based upon Novarossi Parts for the Piston, Sleeve & Button as i have a very unhealthy Piton and Sleeve
Not sure what went wrong, but i did run the engine short period on the lean but today in my club race the ENGINE RAN 100Degrees all day, plenty of power still
Head Shim was Standard in box 0.6mm and 25% nitro fuel.... Race in Australia and run a Novarossi 2015 pipe and 41015 conical manifold....
Can someone help work out where to get replacement parts for my MAX!
Cheers
Frankie
★ DORMANT RC RACER ★
Kodak Hodak is offline   Reply With Quote
Old 04-11-2010, 06:55 AM   #274
MugenDrew's Avatar
Trader Rating: 30 (100%+)
35+21. Crank and bearings are different. It's lean. High speed needle should be close to being flush with the holder. Low speed will be pretty far in. Comes out of the box shimmed for 20%. Thats a hot pipe ya got there. What venturi is in the carb? Are ya making run time? Or did ya lean it out in an attempt to make it to the end? Add a .1mm, better yet add a .05 if you can find some and keep an I on your tuning.
Mugen Seiki Racing Desoto Racing Race AKA Byron Original Fuels Arrowmax Sanwa RC America
MugenDrew is offline   Reply With Quote
Old 04-11-2010, 07:02 AM   #275
Engine on HS is bit over flush so its rich on top, the bottom end is also rich and pretty far out aswell...
Venturi standard 8
Run time only just in 5 mins so the tune was good
I have experience in tune, but something has gone terrible wrong - possibly bad fuel, maybe glow plug, but the O'Donnel 97T seemed to be fine
Never flamed out, never stalled ran very strong and was consistant
Idle no drama was easy to tune but all i can think is either, air leak, not enough head shims, bad fuel or tune settings not correct, but from the information you gave above i was well rich from what you have stated.
So is 35+21 based engine the internals like the head button / piston /sleeve will fit?
Old 04-11-2010, 07:30 AM   #276
kgombe's Avatar
not an onroad guy.. but if you are running that cool then your rear bearing is gone or you sucked in a lil dirt
kgombe is offline   Reply With Quote
Old 04-11-2010, 08:26 AM   #277
roscoe 141's Avatar
Default max power
i have a max SL3 engine i would like to replace the piston and sleeve.where could i find it? and could i use a novarossi piston and sleeve? thanks
"BOARDS DONT HIT BACK"
Go real fast and if you lose your break use the boards
Serpent 733,OFNA DM-1 ,KAMIKAZE RACING
NOVAROSSI, DESOTO RACING,Bruckner Hobbies
FLOY BENNETT RACEWAY
roscoe 141 is offline   Reply With Quote
Old 04-11-2010, 11:07 PM   #278
Osiris 75's Avatar
Trader Rating: 17 (100%+)
I think a Nova LL3/LS3 piston and sleeve will work.
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING / ULTI TIRES
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 04-11-2010, 11:20 PM   #279
Team Kamikaze's Avatar
I have the P/S/Rod with headbutton (complete) for the SL3.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 04-12-2010, 06:49 AM   #280
HSN - can se in photo its RICH
LSN - also rich aswell
Pipe combo: Novarossi 2015 / Manifold 41015 Conical
INS box Xceed Clear
O'Donnell 97T or 99T
I have asked a fellow Aussie Racer Michael Kerr - Sponsor Mugen Driver here in Australia and he said what i have he has run and works fine.....
I can only think what went wrong was bad break-in / Rushed or That one time i had it run tab lean caused this damage.
Bit of a bummer as its only 6 litres of fuel old
Old 04-13-2010, 08:41 AM   #281
MugenDrew's Avatar
What Kgombe said, 6 liters on the factory ceramic is pretty good. Check the rod. I was thinking of the 2013, my bad. Glow plug. Have no Idea about the Odonnel stuff. Im running #7 max power.
Old 04-16-2010, 08:41 PM   #282
GMartinez's Avatar
Head clearance needs to be higher closer to 70 for 25%
looks like a scar/rub mark on the piston
I also use the maxpower #7 or if you can find them grp/ninja #7
Old 04-18-2010, 07:20 PM   #283
the max case is not the same . it has a smaller rear bearing 25.4
rx21wc is 25.8
crank,psr are the same # 8513
DESOTO RACING--SERPENT-977 EVO- 2010/2017 FORGASS -PRES.
RED CUP RACING - -BYRONS FUEL -NUGGETS RACING- RC AMERICA
PICCO RACING ENGINES - SANWA RADIOS - - -http://winternats.blogspot.com
FORT MYERS R/C CAR CLUB MEMBER 1983-2017--FLORIDA WINTERNATS 1988-2017
jrice is offline   Reply With Quote
Old 04-18-2010, 08:12 PM   #284
rx21wc is 25.8
yes you are correct the MaxPower XL7 has a different case with the smaller bearing 25.4 but i thought his engine was a XLTQ9 that does have the same bearing as the RX21WC 25.8
Old 04-22-2010, 05:27 AM   #285
Hey Guys, since my MAX photos in previous post, i finally got myself NEW piston sleeve and button head, went for optional parts Novarossi 35PLUS21 "Lostallo 9 port" this was the information on the package from a Australian supplier Radical RC Hobbies - they looked after me well so i cant complain.
So far everything is going well in the breakin procedure, i have done 2 tanks, the first being a heat cycle process from Ron Paris tips....
Now doing a full flush and in the next few days it will see the track for some easy laps....
Ill report back next week to see how i went in the South Australian State Tittles...
Cheers
Frank
Max Power .12 and RB .21 engines dodgeguy R/C Items: For Sale/Trade 7 05-27-2008 09:13 AM
Max Power XXL3 engines on ebay? rx7ttlm Nitro On-Road 14 04-17-2008 12:13 PM
.12 Engines sale all new pipes too. 6 engines ericsp2 R/C Items: For Sale/Trade 1 08-06-2007 02:19 PM
Getting outta rc HUGE SALE ENGINES A BRUSHLESS T4 TIRES POWER SUPPLY! AE guy R/C Items: For Sale/Trade 0 07-07-2007 09:43 PM
Anybody try those Max Power buggy engines SupermaxxRich Electric Off-Road 1 07-14-2004 01:19 AM
