Old 10-07-2014, 12:57 AM   #1
Aza088's Avatar
Default Engines and Hot weather
Hi All,
What is everyone doing with there engines when the air temperature reaches 30deg c (80deg F). Example more head shims different Plugs etc.
Also do you do anything different when the temp rises above 35 deg C (95 deg F)
Is there a rule of thumb everyone follows?
Shepherd | Brilliant RC | Matrix | Maxima | Xceed | KoPropo
www.bluerc.net
www.hobbyexpress.com.au
www.hootrc.com.au
Aza088 is offline   Reply With Quote
Old 10-07-2014, 01:38 PM   #2
lil-bump's Avatar
Trader Rating: 83 (100%+)
When the temperature gets above 70f(21c) I move from a #5 plug to a #6 plug. Rule of thump the hotter air temps the leaner the carb settings. I only run 16% nitro in a .12 size Novarossi engine.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 10-07-2014, 02:01 PM   #3
Roelof's Avatar
Send a message via ICQ to Roelof
If your engine has a low CG cooling head you can mount a normal head from a cheaper motor. It will be placed higher and so will get more airflow which is comming through the front window.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 10-07-2014, 04:22 PM   #4
dan_vector's Avatar
Trader Rating: 27 (100%+)
Just change to a cooler plug. 5/6 or 7/8 depending on what size engine we are talking about. Then off course retune the carb to suit the different operating environment. I wouldn't bother changing heads as I've never had an issue running the low cg evo heads on my novarossi's in temps exceeding 35 degrees (personally never seen anyone do that).
Serpent Viper 977e EVO2, Serpent Viper 988 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.1, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 10-08-2014, 03:10 AM   #5
Roelof's Avatar
In the 1/8 it is done a lot and it does give lower temps. The Keep-on and other models with a low CG head can handle a normal head like from a Flash.
