Old 08-27-2014, 12:38 PM   #1
1/8 IC Fan's Avatar
Trader Rating: 51 (98%+)
Default Serpent RTR Novarossi P3 SX - Pullstart Delete, backing plate SOLVED
Had a question, helping a buddy out who has a Serpent Cobra GT RTR GP. He asked me about the ability to use a Starter Box, as he was tired of the yanking, and having seen me start my 1:8 Pan Car with a box wanted the same convenience.
I looked through his manuals, for the car and Engine and have not seen any optional numbers or parts. Then I look at Serpents Site and see that under the product info half way down in the Engine description it states that Novarossi offers a Special backing plate! Is that the case as I have not seen one?
Is this going to be a case of grinding the pull start extension off the crank, polishing the crank wrist pin face and putting on a Non-PS Backing plate.
Also given that I have not seen much of the P3 Mill is the P5 case identical, would I be able to use a P5 backing plate? Also would the Turbo Button from a base P5 work in his motor. I have many turbo plugs and have not run standard plugs in a motor in over 6 years - so I have many spares that he can use instead of ordering or getting ripped off at the LHS.
Any help would be great.
PS:
Serpent USA Stated Novarossi does not make such a plate.
(Update per Serpent USA - P5 Backing plate is too big, and as such will not work)
->The Free Shipping I offer is for CONUS only, if you want to buy something I am selling from out of Country, then you will have to pay regular shipping!
1/8 IC Fan is offline   Reply With Quote
Old 09-01-2014, 06:12 AM   #2
1/8 IC Fan's Avatar
Problem Solved thanks to Davide at Novarossi. Here is the part, and possibly anyone else inquiring.
Old 04-27-2016, 12:12 AM   #3
cczjordan's Avatar
is the nvr 13025 working, i need to buy 1. thanks
serpent SRX8
AKA/savox/Sanwa
GO engine/Novarossi/rex
byron/Rapicorn/Max-racing products
mı²
cczjordan is offline   Reply With Quote
Old 04-27-2016, 02:45 AM   #4
Roelof's Avatar
Send a message via ICQ to Roelof
Anoter backplate from a same type crankcase will fit but only when you grind off the pin for the pull start. The size (diameter) backplate is depending the size main bearing.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
