Old 07-10-2014, 07:14 AM   #1
Default NovaRossi .21 Race 2012
I received with a circuit car I purchased recently a fitted used Novarossi which I cannot find any information on ?, so looking with help about specs please.
The Purple annodised head is laser marked with the words Novarossi, 2012, Race.
On one side of the crankcase it has the "Nova 21" emblem and on the other side "Plus 2"
I haven't stripped the motor so have no idea whether its a 7 or 9 port ?
I've tried the Novarossi website but there is nothing listed under current or discontinued motors? maybe it was a special edition ?
Any help appreciated as id like to identify exactly which model it is in the range for obtaining replacement spares.
Cheers
8thracer is offline   Reply With Quote
Old 07-10-2014, 11:27 PM   #2
dan_vector's Avatar
Trader Rating: 27 (100%+)
Need a picture of the head please. It may be a 35plus21 but those engines had 35Plus21 on the head. Most of the Novarossi plus 2 series shared fairly common parts. If you can post a picture of the head that would help a lot.
Serpent Viper 977e EVO2, Serpent Viper 988 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.1, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 07-11-2014, 03:42 AM   #3
Roelof's Avatar
Send a message via ICQ to Roelof
Plus2 is something like a 359. It was delivered in a package with a practise engine.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 07-12-2014, 12:13 AM   #4
dan_vector's Avatar
The 359 had a blue head if I'm not mistaken? It was part of the Plus 2 era but I'm sure had a blue head...
OP we need a photo of the engine to be able to better assist here...
Old 07-12-2014, 02:35 AM   #5
Image of the motor head
Old 07-12-2014, 02:47 AM   #6
These are images of both sides of the crankcase. you can just make out Nova 21 and Plus 2 on the other side.
Old 07-12-2014, 03:27 AM   #7
dan_vector's Avatar
Looking at this to me it seems like it's not the original head. The carb and engine mount shape screams 359 to me but the head is wrong. An easy way to tell if it's a 359 is the size of the crankshaft pin. It's smaller than all the other nova .21's and has P1 etch on the rod instead of R1.
Old 07-12-2014, 06:24 AM   #8
Not sure you are right about the head ? Don't forget the crankcase is stamped Plus 2 So I can understand if its part of the two pack engines, but would this be the practice engine in the pack ? Just taken the backplate off and as can be seen from the image its a P3 conrod. So even more puzzling perhaps ?
Old 07-12-2014, 06:27 AM   #9
If its equivalent to a 359 id be happy as they are good motors aren't they ?
Old 07-12-2014, 07:00 AM   #10
wingracer's Avatar
Trader Rating: 24 (100%+)
P3 rod means it's a 359. Not the most reliable motor Nova ever made but pretty quick.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 07-12-2014, 07:20 AM   #11
OK so when you reliability issues is that mainly with the rods and bearings ?
Old 07-12-2014, 08:22 AM   #12
wingracer's Avatar
Mainly rods and crankpin. I never had any issues with mine but others did. Maybe because I tend to run extra castor in my fuel. I always loved how it ran.
Team Shepherd USA
Old 07-12-2014, 08:50 AM   #13
Roelof's Avatar
Smaller crankpin means less rotation speed giving a better lubrication but the smaller pin does also give more cinter pressure causing rods to split or shattered bushings.
Old 07-12-2014, 10:01 AM   #14
dan_vector's Avatar
I had 3 359's and all failed at the crank pin. Especially quickly on bumpy tracks - in the uk like Brooklands. I lost 2 359's there on one day. Some people 'fixed' the problem by fitting a flash crankshaft and R1 rod. This was the predecessor to the early flash engines and so the rest of the engine is compatible with the flash.
Old 07-12-2014, 10:03 AM   #15
Ah OK so as a precaution then its better to change the rod earlier? I may well get a new rod now as I have no idea how much running this engine had in the past. But thanks guys for ID ing it and for the info as its better to be fore warned
