-   Onroad Nitro Engine Zone (https://www.rctech.net/forum/onroad-nitro-engine-zone-71/)
-   -   Rex RER12S5 (https://www.rctech.net/forum/onroad-nitro-engine-zone/80904-rex-rer12s5.html)
xrcbuggy 08-15-2005 12:47 AM
Rex RER12S5
I need some help with this engine please, Novarossi site is down or is gone & there was no info. on factory setting for carb. inside the box. Need to know low & hi factory setting. I have set the mid. setting flush w/body of the carb.
xrcbuggy 08-19-2005 10:54 PM
I can not believe this, 24000 + member & no one has helped or post where I can get help here???
rge63 08-20-2005 09:46 PM
start with the high side flush
and the low side at least 3 full turns out and work from there.... 5 ports are fun to tune.. does it have a restrictor in the carb?... use it if it does..it will make it easier to tune
Good luck :D
xrcbuggy 08-23-2005 10:15 PM
Thank you.
