Old 04-03-2014, 10:44 AM   #1
Trader Rating: 26 (100%+)
Send a message via AIM to chaos2984
Default Novarossi 353 M3 engine carb help
So i picked up a nice used 2008 novarossi 353 Murnan modified enigne. Has good compression and i went thew the engine and everything checks out nothing needs replaced. I am having issues with the carb on the LSN only. I put a new glow plug in it the 6 and tried to run it and it wouldnt start and it was kicking fuel out of the carb. I leaned the LSN and retried and finally got it to run. So i started to tune the engine. I seemed to get it and the enigne has lots of power. But im kinda worried about the low speed needle. I had to almost close the LSN completly for it to run at all. The low end doesnt seem lean at all. it has plenty of punch on the low end and doesnt bog if you let it sit and idle for about 10 sec it just takes off. Has plenty of smoke on the low end also. Im wondering if there is something wrong with the seating of the LSN on the spray bar when at idle. Im wondering if i have to replace the spray bar and LSN or just try the LSN or have to get a complete carb to fix it. I have heard there was carb issues with there?
What do you all think.
Owner of D&D collectible toys
garage xray m18(2) 416x nitro rs4 nitro rs4 3 evo traxxas slash hpi savage Xray NT1 MTX4R Tamiya 416x a few nice planes in my hangar.
chaos2984 is offline   Reply With Quote
Old 04-08-2014, 01:08 PM   #2
Grinder's Avatar
I say if it runs good, run it.
How far is almost closed? Usually the lsn will be 1.25 to 2.25 turns out on that engine.
www.murnanmodified.com
Grinder is offline   Reply With Quote
Old 04-08-2014, 05:26 PM   #3
its maybe right near 1 maybe a little under. Yea thats how I'm going with lol. its tuned in for current temp and its screams and temp is good.
Old 04-08-2014, 07:46 PM   #4
nitrodude's Avatar
I used to have JP P3L that was a rocket! It was a fast some JP Eagles, but the only way it ran correctly was with the low end needle screwed all the way in, thread bottomed out. It also had some wierd cut on the crank.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 04-08-2014, 10:14 PM   #5
snuvet75's Avatar
Trader Rating: 16 (94%+)
I have 353 2009. My LSN is all the way in then screwed out 1/2 turn. The engine is designed that way. Plenty of smoke and kicking ass.
Capricorn LAB C03, Capricorn LAB C803, Serpent Project 4X, Serpent Spyder SRX2, Mugen MTC-1
RCTarget, DeSotoRacing
snuvet75 is offline   Reply With Quote
Old 04-09-2014, 07:33 AM   #6
ok just making sure cuz my os xz is like maybe 3/4 turn beyond flush with the lsn. and the 353 M3 is like barried lol. It runs like a raped ape so fast. But has plenty of smoke on the bottom and top end and idles smooth. It take a little to warm the enigne up but once its warm it screams (low 60's for ambient temp outside) But once it warms it idles great and doesnt shut off or anything.
Old 04-09-2014, 08:40 AM   #7
GREGORY!'s Avatar
can you measure the lsn in length?
overall length,end to end.
" kyosho rrr wc-team orion crf "
" serpent 966-mega zx21 EM "
" mugen mbx6-picco p7r evo 2 "
GREGORY! is offline   Reply With Quote
Old 04-09-2014, 11:09 AM   #8
you mean actually pull the needle out of the carb and measure the needle from tip to screw tip?
Old 04-09-2014, 12:29 PM   #9
CurveTracer's Avatar
Default NR353 LSN setting
The LSN on my engine is 2.5 turns our from fully closed.
I am using 20% nitro fuel with 0.4mm head shim thickness.
"Yellow Jacket" Mugen MTX-6, Picco Torque
TeamNITRO RC Club, Lynwood, Illinois
CurveTracer is offline   Reply With Quote
Old 04-09-2014, 01:06 PM   #10
GREGORY!'s Avatar
Old 04-09-2014, 01:06 PM   #11
dam 2.5 out from closed I'm using 20% also
Old 04-09-2014, 01:46 PM   #12
What is your head shim thickness?
and how is your HSN set?
Old 04-09-2014, 02:14 PM   #13
HSN is just below flush and i don't know the shims just whatever came with the engine. Ill have to take the head off and measure.
Old 04-10-2014, 02:53 PM   #14
I'm running 2 shims one at .30mm and other at .15mm for total of .45mm
Old 04-13-2014, 01:36 PM   #15
GREGORY!'s Avatar
How much nitro?
