Old 02-14-2014, 05:01 PM   #1
Post Glow plug depth
I've been looking at my head button on my Tt .28 bxr. The manual says to use a os 8, which is shorter then the equivalent McCoy 8. The McCoy 8 fits nice and flush with the button. The os8 has 1/8 gap from button to plug. I know the McCoy will add more compression but do u think Ill get more power( a better burn) with the plug being flush at the bottom of the button.
Rclb4x4 is offline   Reply With Quote
Old 02-14-2014, 11:20 PM   #2
dan_vector's Avatar
Trader Rating: 27 (100%+)
Doubtful. I'd guess with the plug being lower in the button and maintaining the same head clearance you stand the chance of the engine burning the plugs out and also a risk of pre-det which will damage the piston, head and plug. I'd stick with the os plug as per manual or os plug equivalents. I run novarossi and so stick with nova plugs. Others may do something different but it's rarely a case of just changing one thing it's usually a combination of things.
Serpent Viper 977e EVO2, Serpent Viper 988 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.1, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 05-14-2014, 04:45 PM   #3
Not many actually react to this and continue using the short OS plugs in engines that should use a longer plug.
The plug shall always be flush with the button. Using a short plug will decrease compression ratio ---> less power.
On top of that the glow element in the plug will be further away from the button and will make combustion worse ---> the engine will be harder to tune.
I used to have a TTR 21 Pro BX-R engine and using a short OS plug made it perform pretty bad compared to the correct length plug.
SManMTB is offline   Reply With Quote
Old 05-25-2014, 04:17 PM   #4
Anf
Ah but the OS8 is a hardy plug and it will "work" fine in many low rent engines.
Given the choice of course the longer plug is more appropriate.
Anf is offline   Reply With Quote
