Old 11-21-2007, 06:20 AM   #16
Default where are the maxpower offroad engines
where can i get maxpower buggy engines from rcamerica has none? any sites?
younghovaa is offline   Reply With Quote
Old 12-05-2007, 09:05 AM   #17
Osiris 75's Avatar
Trader Rating: 17 (100%+)
Does anyone know who sells the Max Power XL3?
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING / ULTI TIRES
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 12-06-2007, 06:42 AM   #18
word of warning on the SL3!!'s get youself 3 spare conrods for this engine!
i have a SL3 which has had 5 litres through it, and the conrod is already dead. i have busted 3 plugs and pitted the top of the piston and the headbutton. I use runnertime and did not change the tune from the last time i used it.
these engines are possibly the best .12 i have ever run, but they stay tight, (ie read locking up) even after 3 full race meets after break in.
change the conrod 1 litre after break in (ie, break it in, race for 1 litre then change).
i would also recommend changing the rod after another 5 litres, then again after another 5. you will find it is still locking up after 5 litres, and you may still need another rod change after 10 litres.
also to avoid pitting the head button or the piston by accidently running a loose conrod you might want to ad .10 worth of headshims to increase the head clearance.
great engines, but be prepared to change rods due to the engines very thight fit.
TomB is offline   Reply With Quote
Old 12-07-2007, 01:24 AM   #19
The rod are not any worse than other Nova based engine. They are the same rod!
As for pitting... head clearence has nothing to do with it. Unless your rod is stretch to a point it hit the head, then you have a lot more problem than pitting. Pitting is to do with running too lean. The hot combustion is what caused the pitting.
Engine has to be tune each day you run it. An agressive tune means you will need to retune it between days. Slight change in humidity, temperature...etc could push it cross the line to be too lean.
twoo is offline   Reply With Quote
Old 12-07-2007, 01:50 AM   #20
yeah the rods are the same yes i know, but the piston sleeve on the max.12 is alot tighter. my conrod had alot fo play at TDC...i mean alot. so i'm thinking this caused issues with the tune, or something. even after richening it, it blew a plug. i ran a similar tune to last time, yet it was either way out, or something else was going on. Last time i ran the engine it was fine. I've never experienced such a large change in tune, over a 2 month period, this is why i assumed, and still think the rod has something to do with it.
i'll be changing the rod and button and richening it up heaps next time i run it., and see what happens.
Old 12-07-2007, 01:09 PM   #21
stefan's Avatar
Send a message via AIM to stefan
Get your facts right.
Head clearance has EVERYTHING to do with pitting /detonation. If your clearance is too tight, compression will be to high and your fuel mixture will ignite too soon, i.e. before the piston reaches TDC. This is called detonation and causes the sandblasted look you are calling pitting.
It's also deadly for your conrod. A too hot plug will further increase the problem since it will tend to pre-ignition as well......
stefan is offline   Reply With Quote
Old 12-08-2007, 06:11 AM   #22
cheers Stefan. this is, i think, exactly what has happened. the max's come with ony 1 silver shim (thick type, i think it is .3mm) it probably needs another .10mm shim)
now i know....expensive way to learn though and it was my favourite engine. It's still pritty tight though.
if you are thinking of buying one of these engines don't hesitate, but place an extra .10mm or maybe even .2mm head shim clearance from the moment you start it up
the XL3 is also a different motor, it is a short stroke (rev type engine) the older SL3 was a torque, long stroke engine. Personally i think the longstrokes are better, easier to drive as it doesn't require revs to make power, so you can be smoother and a little slower on rolling on the throttle yet still be quick out of corners.
.:Go Engines vs. Jammin Engines:. lanerbrainer205 Nitro Off-Road 20 12-23-2007 04:46 PM
.12 Engines sale all new pipes too. 6 engines ericsp2 R/C Items: For Sale/Trade 1 08-06-2007 02:19 PM
os engines compared to rb engines rhymster Onroad Nitro Engine Zone 4 08-03-2007 05:13 PM
IDM engines and picco engines foampervert Onroad Nitro Engine Zone 5 11-23-2006 05:36 AM
SH engines crazyjr Onroad Nitro Engine Zone 7 01-20-2006 03:13 PM
