Old 12-09-2013, 08:08 AM   #1
Default Maxy's Modified Engine
Check Web Site for Maxy's Modified Engine Special Prices.
http://www.maxysfuel.com/searchresults.asp?cat=1828
http://www.maxysfuel.com/searchresults.asp?cat=1816
Maxy's Fuel
Maxy's Cuatro BT (4 Port) Off Road Engine
Maxy's Cinco BT (5 Port) Off Road Engine
www.maxysfuel.com
maxy is offline   Reply With Quote
Old 03-05-2014, 06:07 AM   #2
Pit-racer's Avatar
Maxy, I've decided to use your engines this year for racing. Which do you prefer for GT8 on-road cars? I just picked up a Cinco tuned. But at the bigger races like Byron's and Homestead which would be more beneficial in my Serpent Cobra GT.
Team Misfits / www.igthobbies.com / Desoto Racing / Veytrex.com / JZRacing / RcShox / IGT8 '17
Pit-racer is offline   Reply With Quote
Old 03-06-2014, 10:53 AM   #3
Pit-racer's Avatar
I guess he don't like on-road.
Old 03-07-2014, 02:03 PM   #4
Gael L's Avatar
I don't think Maxy checks RCTech too often but it would seem most of his team drivers have gone with the Cinco BT. Both engines are good but Cinco recently won the winternats at Fort Myers and had plenty of top end to perform very well at Homestead. Cinco has excellent run time and does not lack on power.
Gael L is offline   Reply With Quote
Old 03-07-2014, 06:52 PM   #5
Pit-racer's Avatar
Thank you for the response.
Old 03-07-2014, 07:21 PM   #6
Cinco for Roar Race, and Siete for Open Race
Maxy's Fuel
www.maxysfuel.com
Old 03-07-2014, 07:21 PM   #7
Hahaha Yes I like on road too, And too Busy, Sorry for late response.
Maxy's Fuel
www.maxysfuel.com
Old 03-11-2014, 09:11 PM   #8
Pit-racer's Avatar
Hello Maxy, do you still recommend a .70 head shim and a c7tgf plug for the Cinco tuned for GT8 on-road race cars? Also I believe needle settings are off. What would be the stock needle settings on the Cinco tuned to start over.
Old 03-12-2014, 08:07 AM   #9
0.70 Is fine and NOVC7TGF.
Stock Needle Setup
The high flow needle (main needle) set to adjust the debit of the fuel must be clockwise turned in totally closed
(do not keep so as to avoid damaging or blocking the needle in the spray bar), and then opened again 3,5 turns.
The low flow needle must be turned in totally and then open again 5 turns.
Maxy's Fuel
www.maxysfuel.com
Old 03-12-2014, 09:09 AM   #10
Pit-racer's Avatar
Thank you, I will start from there. Now I need to start tuning to keep it running when I pull throttle , idles fine.
Old 04-16-2014, 07:36 PM   #11
Pit-racer's Avatar
Stock Needle Setup
Would this be the same for the Siete ..... 0.70 Is fine and NOVC7TGF ?
Old 04-21-2014, 09:35 AM   #12
Pit-racer's Avatar
