Old 04-10-2014, 08:19 AM   #76
Originally Posted by beebone View Post
I tried OS RP6, the power is back. Timing problem.
i use no.7 plug due to weather issue
kyosho malaysia is offline   Reply With Quote
Old 04-10-2014, 11:09 AM   #77
afm
afm's Avatar
Originally Posted by kyosho malaysia View Post
as i know for small track we use hotter plug to gain more torque,maybe i'm wrong
Experience dictates that just by lowering the head (more compression) you gain more power especially in lower rpm range, idle quality can suffer, but the engine also runs cooler . Also, that a higher head (less compression) will increase top rpm speed on bigger tracks.
A decrease in head shims (an increase in compression ratio) will increase torque because as the compression ratio goes higher, the actual ignition timing occurs sooner. However there is a point of diminishing returns where detonation occurs or engine temps can soar, and if this happens a colder plug can help.
When you increase head shims (a decrease in compression), top end is enhanced as the ignition timing is retarded and occurs later. Generally a hotter plug is needed to advance the ignition cycle so that timing does not occur to late in the cycle, but at this point you end up over leaning the engine to get it to rev properly and the engine life will suffer dramatically.
On a .12 engine we would only advise going 0.10mm over or under 0.46mm, so that is 0.36mm or 0.56mm of total head clearance at sea level.
Generally on a .12 engine 0.10mm will change the compression ratio about 3/4 to 1 point..
We should also state that the comments with regards to plugs and head shimming are when both are used together.
Used alone (same chamber) a hotter plug will rev harder, giving more top end and a colder plug will make more torque.
Hope it is clear now
AFM
afm is offline   Reply With Quote
Old 04-11-2014, 08:41 AM   #78
AFM
Ok, so make it clear. Here is the trials that I was found:
1.) Original setting (sleeve shim, head shim, OS PR7, head clearance 0.53mm): no low end power and top end power, heavy smoke
2.) no sleeve shim, add 0.1mm head shim to maintain head clearance 0.53mm, OS PR7:Low and top end were back, visible smoke trail, engine getting hotter 110C
3.) Sleeve shim, head shim, OS PR6, head clearance 0.61mm): Low and top end were back, still heavy smoke, hotter 120C
4.) Any suggestion to maintain normal temperature around 105C, less smoke and good low / high end power?
GP: Capricorn C03 1/10 touring, Capricorn C803 1/8 onroad
Engine: Tesla .12 WC, Tesla .21 7 port on-road, Rody VS02, OS 2101
beebone is offline   Reply With Quote
Old 04-11-2014, 12:17 PM   #79
afm
afm's Avatar
It is very difficult to suggest a récipe just by theory without beeing on the field. There are other factors to take into account with every change you are making
-carburation
-clutch setting
-pipe
-gear ratio
-gear box setting
Any way its a sesión of trying different things in an organized way, keeping record of changes, and by the way, don´t be obsessed on the temp issue....every engine has its ideal working temp. as long as it smokes good coming out of turns and power doesn´t deminish during the lenght of vthe heat.
regards
AFM
Old 04-11-2014, 01:30 PM   #80
Smile
-carburation
-clutch setting
-pipe
-gear ratio
-gear box setting
regards
AFM
got it man!
Old 04-11-2014, 08:28 PM   #81
-carburation
-clutch setting
-pipe
-gear ratio
-gear box setting
regards
AFM
Old 04-12-2014, 05:24 AM   #82
DS Motorsport's Avatar
Contact Patrizio from XRD/Capricorn either through facebook or send him an email.
They are doing a lot of testing with the XRD engines, he can help you out.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 04-12-2014, 08:05 AM   #83
Thx!
I realize that gear ratio and sleeve shim fool me around.
I believe the XRD engine developed base on Capricorn car.
Old 04-12-2014, 11:39 AM   #84
nitrodude's Avatar
The amount of smoke has a lot to do with the brand of fuel you're running. Some fuels smoke more than others...
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 04-13-2014, 08:14 AM   #85
fully syn will be less smoke and no residual
Old 06-03-2014, 02:43 PM   #86
0,5 underhead
Plug number 6
CapricornRC is offline   Reply With Quote
Old 07-02-2014, 11:09 PM   #87
Yes I did, they replied me once said what kind of pipe I used. It's original Hipex made pipe. Then I didn't receive any reponse. So I give up the engine cause the engine nut thread on the crank shaft were off, and no more compression.
Also I tried the .12 tune engine, it's nightmare. Fuel leak non stop from carb lock. It really a good engine, but the material quality.
Old 07-03-2014, 12:06 AM   #88
Hi there,
I will be running this engine in a tropical climate with air temps averaging about 35 degrees celcius.
Can anyone let me know the average temps I should be running the .12 (hard tuned version) engines at?
thanks in advance
sam
sammies is offline   Reply With Quote
Old 07-07-2014, 08:36 PM   #89
Trader Rating: 13 (93%+)
Originally Posted by sammies View Post
Hi there,
thanks in advance
sam
In Australia we run them max 85-90 degrees celcius
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 07-13-2014, 07:46 AM   #90
ali_g's Avatar
Originally Posted by CapricornRC View Post
0,5 underhead
Plug number 6
is it necessary? I'm looking at the .21 5 port engine
☆ JU.C RACING ☆
https://www.facebook.com/Ju.Cracing
ali_g is offline   Reply With Quote
