Old 07-08-2013, 08:45 AM   #1
g-wan's Avatar
Send a message via MSN to g-wan Send a message via Yahoo to g-wan
Default piston sleve crack
mind to know what make the sleve crack and broken into 2pc i never encounter this problem before...i just encounter piston crack and broken into pieces..crankshaft broke into 2 at the intake..
km k8 / os speed / savox / blitz / contact tyre
km hk1 evo / os speed / savox / sweep
sworkz evo / spower evo s7 / sweep / savox
xray t3 2012 / tekin rs pro / reedy / savox
km racing / sworkz / xray / savox / sanwa / os speed / sweep / ulti / blitz
g-wan is offline   Reply With Quote
Old 07-08-2013, 09:05 AM   #2
wingracer's Avatar
Trader Rating: 24 (100%+)
Too hot, too lean and/or bad lubrication.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 07-10-2013, 02:32 PM   #3
g-wan's Avatar
I think after I change fuel from cosmo to techlube 25% after 3lap then the engine stop and temp around 105 degree on my ninja mr21, I try techlube as my supplier asking to try it out but end up I crack my liner but piston and conrod still in good condition no mark on the piston either the conrod
Old 07-10-2013, 05:04 PM   #4
wingracer's Avatar
I know nothing about either fuel but if the motor wasn't 330 degrees f, my first thought would be the fuel and since you just switched fuels, I would tell him to rethink his formula. If it doesn't contain at least 6% castor, things like that can happen. I bet he was trying an all synthetic blend or maybe a 50/50 (4% synth, 4% castor for instance). Might work for offroad or short tracks but not on a fast 1/8th onroad track.
Team Shepherd USA
