Old 05-28-2013, 03:01 PM   #1
pressure's Avatar
Default Motor compression question?
I have two motors that I race with. I run them pretty hard and they start as soon as they touch the box. I have replaced rods and generally take good care of them however when warm they turn over VERY easily. I have bought new motors primarily because despise race day failure. Is this normal? I was told that if a motor can support it own weight cold then compression is ok. Is this a valid test? I have replacement p/s but was wondering if I'm being prematurely cautious. Thanks
ITS COMPLICATED......................
pressure is offline   Reply With Quote
Old 05-28-2013, 03:10 PM   #2
wingracer's Avatar
Trader Rating: 24 (100%+)
Usually when compression goes, they get difficult to tune and don't hold an idle well.
As for feel, it varies. I have had motors that when cold, you could spin the flywheel with ease even with the plug in. It would run like crap for a few laps but once it warmed up it was a rocket. I also have a motor right now that has at least 4 gallons on it yet it is still so freaking tight that it locks up on the starter box, hot or cold. It's a major pain in the ass to get started but it goes like stink on the track.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 05-28-2013, 03:13 PM   #3
pressure's Avatar
Thanks.
