-   Onroad Nitro Engine Zone (https://www.rctech.net/forum/onroad-nitro-engine-zone-71/)
-   -   Os CV-X / AE .15X Pullstart! (https://www.rctech.net/forum/onroad-nitro-engine-zone/72984-os-cv-x-ae-15x-pullstart.html)
hooked_on 05-21-2005 12:21 AM
Os .12CV-X / AE .15X Pullstart!
Hey guys,
It's been a while since i have played with smaller engines like these and i have a few questions:)
Our club runs a class (Gas Tourers) that must be a .12 or .15 engine within .80hp, it can be wither pullstart or non pullstart with a min weight of 1750 (chassis weight) i think???
Anyway after doing a little research on the two above engines it appears as though you can no longer get the Os .12CV-X with a slide carb. On further research i descovered AE have the .15 engine (AE MDL NO: 2915) again that is rotary carb, but i can't find anywhere a HP rating for this engine????
Also are the AE engines made by Thunder Tiger? And what are they like???
I look forward to hearing from you all soon, if anyone can thing of another option it would be greatly appreciated as well:D
H-O
XRA-AJ 05-21-2005 02:20 AM
ae 15 v's cvx
both engines are fairly solid contenders for that class. i just changed from the ae 15 only last week. very solid motor and stable if you dont want to have to tune it too often. plenty of grunt especially with a 2 speed
hav_lova 05-21-2005 03:08 AM
hooked_on, I would suggest getting the O.S. 12 CV-X and check around at you LHS shops and see if you can purchase a slide carby seperate
I only just noticed your post AJ...
I have witnessed the AE 15 its a quick motor
hooked_on 05-21-2005 03:16 AM
Thanks guys...
My only concern is that if i purchased the AE .15X and it turns out to be alot quicker then the rest of the field i may not be allowed to run it again:(
The .12CV-X is safest bet and i know they are easy to tune, but i also like to be different as well:D
H-O
