SPM Vega engines?
Hey has anyone heard tryied these engines yet?
the .21 onroad 7 port looks interesting , here;s the link: http://www.spmracingparts.com :sneaky: |
i got this from a UK based onlline shop
"...this high perormance engine produces the same power as its rivals but at 8000rpm less, this result in amazing levels of torque capable of slipping a 3 shoe centex clutch!..." Constuction: ABC Carb: Aluminum Head Size: Low profile Head Colour: Gold Capacity: 4.38cc Ports: 7 Stroke: 16.5mm Bore:16.4mm Crank: 14mm SG RPM: 37,000 HP: 2.5 Weight: 340g Specs look good:) |
4.38cc´s
can not be they only makes 3,49cc´s are you sure? |
Originally Posted by Electrolabs
(Post 1589693)
"...this high perormance engine produces the same power as its rivals but at 8000rpm less, this result in amazing levels of torque capable of slipping a 3 shoe centex clutch!..." |
| All times are GMT -7. It is currently 06:42 PM. |
