-   Onroad Nitro Engine Zone (https://www.rctech.net/forum/onroad-nitro-engine-zone-71/)
-   -   Question for the engine guru's (https://www.rctech.net/forum/onroad-nitro-engine-zone/71584-question-engine-gurus.html)
nitrohead5300 05-07-2005 01:08 PM
If you have a motor that has a crankshaft with real small port openings would this motor tend to have alot of low end torque?
BigDogRacing 05-07-2005 02:36 PM
I'm certainly no guru, but the answer is most likely yes. Larger port/port openings tend to move the power curve up in the RPM range, assuming the intake/exhaust and port timing are correctly matched combination.
It's sorta like a full size race motor- increasing the lift/duration will kill the bottom end but make more power up top.
A motor with strong bottom end would be perfect for tight technical tracks assuming there's enough traction to handle it, and you have your gearing close.
nitrohead5300 05-07-2005 03:53 PM
Thanks for your input BDR
