Novarossi Vir-tus.21
#61
Hi guys,
Normally a 500cc bottle is about right. However I found with the new Virtus, you need more time for the break in. If you only use 1 fuel bottle it will not be ready to perform at its best. I would go through the first bottle really on the rich side. Keeping it around 190-205 degrees. For the second bottle keep it around 210-220. Always run the bottom rich in this process as well. One the 3rd bottle you can start running it with a rich race setting. By the fourth bottle you can run it full out.
This is just what I found when I did my first ones.
DJ Apolaro
DJ Apolaro
#62
Do any of you use the included venturi restrictors? If yes, any recommendations which one to use?
#63
Hi guys,
DJ Apolaro
DJ Apolaro
Thanks DJ for your advice. Just to clarify, when you say the third bottle is run with a "rich race setting" do you mean to still run it rich? Or can start to lean it out for a race setting?
#64
You are definitely leaning it out for racing but just running it on the safer side a little rich. you are not running it on the extreme side yet.
Dj
Dj
#66
I believe standard 14.5x26 and front would be 7x19x5
But the main bearing is different in shape that a normal bearing would not fit.
#68
Up to the flash it is a very normal bearing you can find at TKO, Boca etc. for much better prices. The keep-on and the Virtus has a small edge in the cranckase and need to fit a bearing with a smaller (in width) inner brace. Handy people can mill out the edge from the crankcase and fit a normal bearing. I truly believe this has no real technical function than only protecting their after market in bearings.
But probably other RC bearing manufacturers have made a ready to fit bearing for these latest model engines. Just look arround.
#70
Hi guys,
DJ Apolaro
DJ Apolaro
#71
Can someone advise me on the different models of the Vir-tus?
Correct me if I am wrong but is the following what we can buy:
1: Rear ceramic bearing
2: Front and rear ceramic bearing
3: Pre-break in rear ceramic
4: Pre-break in front and rear ceramic bearing
Any more models?
Any more models?
#74
VIRTUS RED DOT
I heard about a Vir-Tus .21/S red dot version. what the difference between the regular one and the red dot team engine? thanks!
#75
