Old 01-18-2013, 10:06 PM   #1
Bundy_Bear's Avatar
Default Clutch Shims Question
Gurus have a question for you... running an Edam Spirit with OS Tg in it. Twice now the clutch shims on the thrust bearing retainer have destroyed themselves leaving just metal filings increasing the gap.
Any thoughts, brother had same issue with the Edam clutch before changing to Capricorn clutch.
Thanks in advance
Andrew
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 01-19-2013, 02:00 AM   #2
rcabj's Avatar
try to replace the trust bearing with other brand's.mugen or kyosho etc...see if it still happens.
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 01-19-2013, 04:17 AM   #3
Roelof's Avatar
Send a message via ICQ to Roelof
On which side do you have the shims, between the clutchbell and the thrust bearing or on the other side of the thrustbearing?
Also, do you have no or a lot of endplay?
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 01-19-2013, 04:23 PM   #4
Bundy_Bear's Avatar
The shims between thrust bearing and clutchbell and no about 0.5mm
MissMooRC Racing
Old 01-20-2013, 03:43 AM   #5
MRX4XXXX's Avatar
The shims must be between the thrust bearing and the end stopper. I've tried it also on the wrong place with the same results.
0.5mm free play is a lot. It should be more like 0.1mm-0.2mm.
-X-
MRX4XXXX is offline   Reply With Quote
Old 01-20-2013, 04:19 PM   #6
Bundy_Bear's Avatar
-X-
Hi
The manual shows them in this spot, i will try them on the otherside and rebuilt it checking all my measurments again.
Thanks for help
Andrew
MissMooRC Racing
New Werks Clutch Redvet79 Offroad Nitro Engine Forum 704 02-14-2016 08:01 AM
Avid Triad Slipper Clutch for AE and TLR Cars ScottKelly911 Electric Off-Road 653 10-22-2015 03:33 PM
New Ascendancy Racing Effortless Racing Clutch janderson78 Offroad Nitro Engine Forum 879 03-06-2013 07:24 PM
