Old 04-15-2005, 08:37 AM   #1
Send a message via ICQ to Grasshopperr Send a message via AIM to Grasshopperr Send a message via Yahoo to Grasshopperr
Default Need Help Tuning My Sirio Evo 2
I have a murnan modified sirio that will not ever run right can anyone please give some Ideas or tips on tung this engine.
Thanks alot, Chance
Grasshopperr is offline   Reply With Quote
Old 04-15-2005, 10:05 AM   #2
TRAJ's Avatar
Have you tried returning it to factory settings and working from there?
TRAJ is offline   Reply With Quote
Old 04-15-2005, 10:10 AM   #3
Yes uriah murnan told me the factory settings.
Old 04-15-2005, 10:13 AM   #4
TRAJ's Avatar
Have you tried them? Once you have run in the motor which i assume you have done lean off the high speed needle before the low end then work from there
Old 04-15-2005, 10:22 AM   #5
Dynamite's Avatar
Send a message via MSN to Dynamite
not having a lean idle problem? try a nova carb if it is, i had this problem with the std evo2 carb, swapped to a nova one and fixed it straight up.
www.racingfactory.org
Kyosho RRR Evo | Sirio Evo III STI | Ko Radio
Dynamite is offline   Reply With Quote
Old 04-15-2005, 10:25 AM   #6
I already have a carb of a MT12 on it.
Old 04-15-2005, 10:37 AM   #7
Dynamite's Avatar
when you say its not running right, whats happening, whats it not doing for you?
Old 04-15-2005, 10:41 AM   #8
It will just be siiting and the idle will sart going up like it is running out of gas and when I let off fromm going donw the straight It trys to over rev for a second or two then it calms down.
Old 04-15-2005, 10:53 AM   #9
Dynamite's Avatar
sounds like bottom ends to lean, saying that i guess by richening it up on the origional carby did no good hence why you now have the MT12 one on it which has made it a little better? worse?
I was suffereing the same problem with my evo2, no matter how close i was able to tune it, it would always have a lean idle problem, got a nova carb threw it on reset to factory settings re-adjusted it up and it was a whole new motor
Old 04-15-2005, 11:10 AM   #10
What are the factory settings I forgott themm, Thanks.
Old 04-16-2005, 02:31 AM   #11
Dynamite's Avatar
This can be found on the sirio page on the trinity website, under <<<< Lattest Service Bulletins >>>>
Bulletin #3
Sirio .12/15/18 (General Carburetor Settings)
High Speed - 5.5 turns
Low Speed - 2-1/2 (Generally this should be flush with the end of the slide)
Mid Range - Flush then one turn out.
Tuning of Sirio Kanai EvoII ReneHolleman Nitro Off-Road 0 02-12-2008 08:07 AM
NEW Kyosho Evolva '07 WC, Sirio CL7R STi and Sirio 2013 Pipe/Manifold Randy Caster R/C Items: For Sale/Trade 9 12-06-2007 01:50 PM
Need Help Tuning My Sirio Evo 2 Grasshopperr Nitro On-Road 6 04-19-2005 07:45 AM
beginner questions re: car tuning and motor tuning! Captjono Rookie Zone 5 02-19-2005 12:01 PM
beginners question re: car tuning and motor tuning! Captjono Electric On-Road 5 02-19-2005 03:01 AM
