Hudy Ultimate Engine Tool????
For engine experts. Did Hudy ever produce a optional cap to pull a 18mm front engine bearing. Currently the Hudy ultimate engine tool will not pull a 18mm front engine bearing. The front cap(.id) is only about 17.2mm.
Pass you soon... |
What engine is that?
Originally Posted by lil-bump
(Post 11173842)
For engine experts. Did Hudy ever produce a optional cap to pull a 18mm front engine bearing. Currently the Hudy ultimate engine tool will not pull a 18mm front engine bearing. The front cap is (.id) is only about 17.2mm.
Pass you soon... |
The Flash PT uses a 7 x 18mm front bearing. I'm not sure about the Keep-On.
Pass you soon... |
| All times are GMT -7. It is currently 05:54 PM. |
