Old 02-21-2005, 03:38 PM   #1
Electrolabs's Avatar
Default MAX POWER MX R12 312 help!!
Hi guys does anyone know the diference beetween this engine and a normal novarossi as this one is not tuned or modified acording to www.rcmaxpwer.com strange...
i just wanted to now what are you getting as normally Max power engines are tuned/modifeid Novarossi engines.
Regards
Electrolabs
Electrolabs is offline   Reply With Quote
Old 02-21-2005, 03:42 PM   #2
sorry posted wrong address
www.rcmaxpower.com
Old 02-22-2005, 09:59 AM   #3
jrabbito's Avatar
Default 312
Electrolabs,
I am the Canadian Distibutor for Max Power engines by Massimo Fantini.
I can assure you that this motor is far better than a stock Novarossi. Here is what it has in addition to to the NS3.
- Tuned cranked. Balanced and drilled out with a silicone insert
- More elements on the head for better cooling
- Piston and sleeve have been matched
Correct that the sleeve itself it not modified like the P3 or S3 motors. Those are full out modified engines.
You can contact me at [email protected] or call me at 416-570-0224 if you have any further questions. We would be more than happy to assist you.
All the best,
John Rabbito
Novamax
jrabbito is offline   Reply With Quote
Old 02-22-2005, 01:01 PM   #4
Thanks allot!!
Old 02-22-2005, 07:30 PM   #5
TrickPonYracing's Avatar
i run all max power motors s3 and the cranks are not drilled but there is silicone in the nose of there crank and the piston and sleave are modded they have a lot of room to work on in the crank area but are vary fast the way they come
www.TrickPonYracing.Com
FORGASS President 2006/2007.2007/2008. 2008/2009
V/P Charlotte R/C Raceway
Team Anchor for .. ReD CuP RacinG ..
Team Driver for TORO Fuel
[email protected]
TrickPonYracing is offline   Reply With Quote
Old 02-22-2005, 08:02 PM   #6
kitracer's Avatar
So the standard Max Crankshaft Not drilled, just silicon inserted?
I guess no weight saving there
interested to know , thanks
kitracer is offline   Reply With Quote
Old 02-22-2005, 09:14 PM   #7
jrabbito's Avatar
Guys,
The crank is touched for fuel flow and the silicone is added. If you hold a stock Novarossi crank and the one from the 312 you will see what I mean. The bore intake has been increased.
Cheers,
John
Old 02-23-2005, 12:46 AM   #8
is that engine based on the picco motor, on the home page of rcmaxpower.com?
Brett.w is offline   Reply With Quote
Old 02-23-2005, 06:36 AM   #9
jrabbito's Avatar
No,
They are all based on the Novarossi platform.
Cheers,
John
Old 02-23-2005, 08:57 AM   #10
kitracer's Avatar
Originally posted by jrabbito
Guys,
Cheers,
John
Thanks, but What I want to know under that "silicon", if they have drilled a hole or just filled.
I like them light as possible..
Old 02-23-2005, 09:25 AM   #11
jrabbito's Avatar
kitracer - the hole entering toward the silicone ("bore intake") is what has been increased. As for what is under the silcone...I ohnestly do not know. So whatever needs to be done to get the power balance right I am sure is done.
All the best,
John
Old 02-23-2005, 11:21 PM   #12
kitracer's Avatar
All the best,
John
thank you again
Old 03-31-2005, 07:56 AM   #13
TRAJ's Avatar
*wrong thread*
TRAJ is offline   Reply With Quote
RC BLOW OUT !!!! Ice chargers,novak discharger,power supply,power bridge,integy setup shrum1340 R/C Items: For Sale/Trade 20 07-23-2007 05:37 AM
Novak N-Power power supply, original box, like new condition!! Scottrik R/C Items: For Sale/Trade 7 05-28-2007 05:04 PM
Novak N-Power 14Volt/10AMP DC Power Supply Guo Chean R/C Items: For Sale/Trade 6 04-23-2007 05:32 PM
>>> TEAM NOVAK N-POWER POWER SUPPLY GREAT CONDITION $50 <<<< mach51 R/C Items: For Sale/Trade 3 02-06-2007 10:53 PM
Novak Millenium Pro charger ans N- Power power supply RobertF R/C Items: For Sale/Trade 11 11-27-2005 08:59 PM
