-   Onroad Nitro Engine Zone (https://www.rctech.net/forum/onroad-nitro-engine-zone-71/)
-   -   rb engine parts (https://www.rctech.net/forum/onroad-nitro-engine-zone/632487-rb-engine-parts.html)
bigtee 05-28-2012 11:19 AM
rb engine parts
where can i buy a piston,sleeve and connecting rod for a rb t9 engine.
Pertn 05-28-2012 01:29 PM
You can buy Nova 8677 piston and sleeve and 8677/11 thats in the Flash, Keepon engine. Conrod for RB is Nova 7601. 7604 does not work due to bigger diameter on the conrod at the crank pin.
TeamCarnage 05-28-2012 02:01 PM
If you go with Nova parts, here you go...http://www.kamikazercracing.com/products
You could talk to one of the tuners too. Rick at RB Mods or Uriah at Murnan Mods.
bigtee 05-28-2012 06:59 PM
rb 09 connecting rod piston and sleeve
not sure about putting in a novarossi base connection rod pistion and sleeve.
why not just put what came out back in? some insight please
Grinder 05-29-2012 04:26 AM
I have the parts on stock.
bigtee 05-29-2012 10:38 AM
rb parts
grinder you have pm
Pertn 05-30-2012 12:01 AM
The RB R3,T9,10,11 are based on the Nova Plus 12-3 and Flash,Keepon has the same piston and sleeve but with new timing.
bigtee 05-30-2012 06:59 AM
rb parts
so if i went with the nova keepin on would i have to change the crank since the keepin on has different timing
Pertn 05-30-2012 10:51 AM
No! I don't remember the timing of the piston and sleeve on the T9 but I have done it on one and it work just fine with Nova 2652 and short manifold.
You just need to change the conrod from 7604 to 7601.
You can get a new O-ring for the new chamber that comes with 8677/11 and use it insted of RB's and get more top end and run time.
bigtee 05-30-2012 12:21 PM
rb 9
not sure what you talking about. what do i need to order from the Grinder
Murnan modified
