Old 01-26-2005, 04:58 PM   #1
DJ_Normal's Avatar
Send a message via MSN to DJ_Normal
Default Break in fuel additives?
So I've got this shiny new .12 CV-r sitting in my RC10 GT and I need to break it in. I think I'll be using the heat cycling method as described here:
http://www.affordablenitrotech.com/f...ct=ST&f=6&t=31
How does this method sound/work for you?
Also another question. I will be using Trinty Monster Horsepower 20% to break the engine in. This fuel already has 12% oil content, but should I be thinking of adding more for the break-in?
Thank you for your time.
DJ_Normal is offline   Reply With Quote
Old 01-27-2005, 07:17 AM   #2
Nitro Tech
dino.tw's Avatar
12% oil content is enough. You just need to remember that don't let the rpm stay at high revs. 15% oil content is the best. But it will take longer when break-in.
dino.tw is offline   Reply With Quote
Old 01-27-2005, 09:25 AM   #3
DJ_Normal's Avatar
K thanks for the reply.
Old 01-27-2005, 09:49 AM   #4
GregH's Avatar
Send a message via AIM to GregH
If you haven't already started the engine, try spraying a shot or two of PB Blaster in the tank before you add the fuel. It will mix in with the fuel and help the break-in proccess. It works wonders and is great for after run oil. Also, heat cycling the engine will help a ton.
GregH is offline   Reply With Quote
Old 01-27-2005, 03:38 PM   #5
Dynamite's Avatar
Send a message via MSN to Dynamite
PB blaster?
www.racingfactory.org
Kyosho RRR Evo | Sirio Evo III STI | Ko Radio
Dynamite is offline   Reply With Quote
Old 01-27-2005, 03:59 PM   #6
GregH's Avatar
it's a spray penetrating oil... works very good.
Old 01-27-2005, 10:02 PM   #7
DJ_Normal's Avatar
Where can I find some?
Old 01-28-2005, 08:04 AM   #8
GregH's Avatar
here's their website...
http://www.pbblaster.com/
It can be found at WalMart and other retail stores in the automotive section.
Engine break-in What fuel % or brand? SasonRC Onroad Nitro Engine Zone 9 09-09-2008 01:15 PM
tire additives? civiceg Electric On-Road 3 04-22-2007 11:02 PM
20% or 30% fuel for 1/8 on-road engine break-in? US_MATRIX Nitro On-Road 4 01-28-2005 02:49 PM
Fuel Additives ?? Roger Onroad Nitro Engine Zone 3 09-09-2004 09:22 PM
Novarossi Break-in Fuel Recommendation Help Needed jcrouse Nitro On-Road 3 07-17-2003 01:43 AM
