-   Onroad Nitro Engine Zone (https://www.rctech.net/forum/onroad-nitro-engine-zone-71/)
-   -   VoneSII Motor (https://www.rctech.net/forum/onroad-nitro-engine-zone/61213-vonesii-motor.html)
nicmaan 01-26-2005 01:53 AM
VoneSII Motor
I have a VoneSII and am having problems with the engine running rough at high revs. I have rebuilt the motor to ensure that there are no air leaks. It has a new glow plug.
When running at higher revs the motor surges and there is a lot of small air bubbles in the fuel line.
Does any one have any suggestions for what is wrong ??
Many thanks to all.
Nic.
Mange 02-03-2005 11:33 AM
Blow in the "fuelline" that is connected to the exhaust for pressure and hold up the "tank cap?" and check so it isn`t clogged. If it is ok, then set you carb to the original settings, this should be explained in the manual. Hope it helps.
