Old 07-01-2006, 06:04 AM   #1291
Seisick's Avatar
rody is right, crankcase, crankshaft, head, carburator, piston, sleeve, conrod
and the carb reducer are not commecially available, for those about getting the speed, should consider that as for now, os is not selling replacement parts for parts mentioned about
so basically this engine should be consider as a limited edition one, I really hope that os will produce at least the p/s/conrod set.
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 07-01-2006, 08:18 AM   #1292
Ed Anderson's Avatar
Trader Rating: 26 (100%+)
Connecting rod is available in the US, $20.00
Ed Anderson is offline   Reply With Quote
Old 07-01-2006, 08:38 AM   #1293
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Yea, conrod is still the same I think. And if you need the piston/sleeve, just purchase a stock 5 port and use a dremmel to turn it into 3 ports... I would be that the difference between those two isnt great.
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 07-01-2006, 07:47 PM   #1294
afm
afm's Avatar
Originally Posted by Riketsu
........... if you need the piston/sleeve, just purchase a stock 5 port and use a dremmel to turn it into 3 ports... I would bet that the difference between those two isn't great.
Yea, as soon as the TZ Speed showed on the market I bought a TZ 5 port and did almost all mods that the TZ Speed shows in pictures...except for the crank....which in the TZ Speed has about 8.5mm bore.....the TZ 5 port has 7.5mm.
Performance of my engine is AWESOME!!!!....I will try moding a crank as the Speed's when I get the proper tooling
AFM
afm is offline   Reply With Quote
Old 07-01-2006, 10:24 PM   #1295
Riketsu's Avatar
AFM
Awesome to hear that... What tools u used to mod the sleeve?
Old 07-02-2006, 12:29 AM   #1296
afm
afm's Avatar
To cut the bridge that separetes the side horizontal port and the side vertical port, I used thin dremel cutting disc, with reduced diameter, then finishing touches with diamond files. Also widened the top side of exhaust port with cutting disc and files.
The mod on the low side of boost port on crankcase with dremel round green stone.
The mods on crankshaft timing and outcoming ramp also with dremel appropiate stones, and made ramp with high temp red 650 Permatex silicone
Very important: use Mugen/Shimo P01002 pipe...it makes a big difference
Engine has so much power that if i'm not carefull with finger and negative exponential on throttle, car spins out like crazy....i'm learning again how to drive..jejejeje...I'm so happy with my new toy
AFM
Old 07-02-2006, 06:31 AM   #1297
itchy b's Avatar
AFM
can we see some pictures of the before and after ?
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 07-02-2006, 01:03 PM   #1298
afm
afm's Avatar
Sorry no digicam. Maybe when I have to do routine maintenance I will borrow a digicam.
AFM
Old 07-16-2006, 12:42 AM   #1299
Secret_weapon's Avatar
Hi,
I have 12 TZ 5 port and its time to change the piston. Can I fix the 3 port piston and sleeve on the 5 port? and is it going to be better ?
Secret_weapon is offline   Reply With Quote
Old 07-16-2006, 01:19 AM   #1300
You can run the 3-port piston and sleeve in the 5-port motor/case with no problems... Always change the conrod when you rebuild your motor... Break the motor in as if it's brand new and as per the owners manual... ie... Setting the carb neddles back to factory settings and breaking in the new piston and sleeve just like you did when you brought the TZ new... Goodluck
RC_Alan
rc_alan is offline   Reply With Quote
Old 07-16-2006, 02:53 AM   #1301
Thankyou ,, But is it going to be faster and easier to tune ? or its actually faster with the 5 port piston and sleeve ? is that going to affect the tuning ?
Old 07-16-2006, 09:24 AM   #1302
Since you're still using the 5-port crank and the 5-port black carb... the venturi's insert is larger... Your performance should be about the same as it was with the 5-port piston and sleeve... Tuning both motors are easy... Remember to change the conrod along with the new 3-port piston and sleeve...
RC_Alan
Old 07-16-2006, 09:47 AM   #1303
thankyou very much
very helpful !!
Old 07-17-2006, 07:12 AM   #1304
Trader Rating: 15 (100%+)
The carb on my OS TZ .12 broke and do not have one for this weekend coming up. Will a Novarossi carb fit on the OS engine?
THE DOCTOR is offline   Reply With Quote
Old 07-17-2006, 09:47 AM   #1305
No... The Nova carb will not fit... You say the OS carb broke... What broke??? The only carb that is a direct fit is Traxxas... ie. TMaxx/Revo... So, if I were you, I would fix the one you have or buy a new one...
RC_Alan
