Old 02-21-2006, 03:42 PM   #991
AndyT 's Avatar
Originally Posted by vti-chris
Also what plugs do you use and how much nitro% and oil% in your fuel!
Also your runtimes and temps.
I raced the ZAC OS last weekend using a OS #6 plug.....16% nitro, 11% oil......runtime was around 6 minutes +.....highest temp it got to was 220 deg f. The engine ran extremely well
Cheers
AndyT  is offline   Reply With Quote
Old 02-21-2006, 04:23 PM   #992
Originally Posted by Ivan Dickson
Where is the engine avalidable now?
All I need is a part number... Anyone???
RC_Alan
rc_alan is offline   Reply With Quote
Old 02-21-2006, 04:49 PM   #993
Trader Rating: 44 (100%+)
Cheers
where in syd did u race last weekend? EC?
YOKObori MOkei
wyl03 is offline   Reply With Quote
Old 02-21-2006, 07:23 PM   #994
RC_Alan
ZAC OS 12TZ 3 port engine P/N #Z-1912
5 port engine P/N #Z-1913
A380 is offline   Reply With Quote
Old 02-21-2006, 07:32 PM   #995
Sorry, i make a misunderstood about u ask Zac engine.
here is the link about OS speed TZ12
http://www.os-engines.co.jp/index_j.htm
No part number issue now.
Old 02-21-2006, 07:58 PM   #996
Thanks for the info...
RC_Alan
Old 02-21-2006, 11:50 PM   #997
chippy's Avatar
Default MSPEED
You could also try here
http://shop.racefactoryrcp.com/store...?idCategory=27
chippy is offline   Reply With Quote
Old 02-22-2006, 02:05 AM   #998
AndyT 's Avatar
yep EC on the 11th it was
Cheers
Old 02-23-2006, 10:41 PM   #999
vti-chris's Avatar
Has anyone removed the 0.2mm head gasket from his 3 port TZ?
I'm running 16%nitro and the engine has run about 1 Gallon of fuel up to now can i remove the 0.2mm shim as the manual says?
As i told you before i'm having problems with tuning and i saw the manual on-line and it says to remove the 0.1shim even for higher nitro contents.
NEED HELP ON THIS ONE...!!!
vti-chris is offline   Reply With Quote
Old 02-24-2006, 04:23 AM   #1000
ziggy12345's Avatar
Check the head clearance using the solder method. It should be 0.4mm for 16% as this is a long stroke engine
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 02-24-2006, 04:54 AM   #1001
vti-chris's Avatar
Solder method...???????
Isn't there a simple way.
In or out the 0.2mm gasket?????(or the 0.1mm)
Old 02-26-2006, 01:10 AM   #1002
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Is an OS pipe really necessary to go with this engine? I plan on selling my Rody for one and wondering if the RB 401 pipe will work great with it...or send it back for another pipe? THey (my LHS) don't get RD logics or skyline so its THS, Nova, or RB pipes only. I'll be running 30% byrons.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 02-26-2006, 08:12 AM   #1003
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
You can always order the Skyline VR12 from their website. I believe its the same price as LHS have.
Riketsu is offline   Reply With Quote
Old 02-26-2006, 09:23 AM   #1004
HarKonnenD's Avatar
Still though, is the OS the best pipe or can I go with my RB or any other?
Old 02-26-2006, 09:44 AM   #1005
The TZ-12 will run great with the RB & Nova pipes... Proper engine break-in is key... Break the motor in as per manuel and heat cycle the motor between fuel refills, fuel type, fuel %, and plug type will also play a big roll in the engines performance... As well as getting it tuned for Peak power... The motor will run fine with the needle setting close, but once it's tuned for Peak Power... You'll hear and feel the power... You can also pick up the TZ 5 port crank for $25.00 and have your own modified TZ ....
RC_Alan
